Unable to lift up top cover due to motor cables
SOURCE: broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
SOURCE: The cd laser needs to be replaced beocenter 2300
Hi, download the manual at http://www.beomanuals.com/ for free
SOURCE: beocenter 9000 cd player problem. it won't start.
the disc isnt being read. the laser lens may be dirty or the laser power cct may be faulty. check tr6108 and c2103 located on the servo board beneath the mech.(bc338/33uf16v).
SOURCE: I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
SOURCE: Hello, my CD-Player on the BeoCenter 9000 does not
the doors are belt driven so change the belts first and clean the door guide rails.p/n2732076
