My 8n (6 volt) will not start. Great spark ,getting fuel turns over but will not fire. I have tried everything please help.
thanks Rob
Spark to plugs is great?.....but if they are black (carbon coated) it may not start.
Crank her over and use that choke for 30 seconds.
Pull the plugs ...are they wet with gas?Smell it....is it water or gas.
They should be wet with something.
Are they dry.........No fuel.
If they are wet with gas and NOT black carbon coated and you are SURE you have spark..........time to tow it to start.
You want to turn the engine fast enough to have the crank throw oil onto the cyl walls. Engines need a oil coated cyl wall to run....to seal the rings.The gas from flooding the engine washes the oil away.Put it back and it should fire up.After the first start...it should be OK.
I've started many a engine that others could not start (flooded or sitting for years) with a little oil in each cyl to seal it.....but towing is the better choice if possible.
