When I play my records there is no bass. The music is very thin. Any ideas?
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
SOURCE: Kenwood KD-76F Turntable Problem
There is an adjustment in the postion sensor switch of the tone arm located under the support housing. BE VERY CAREFULL in lifting or fliping the unit over. If you can lock the arm in postion please do so before proceding. There may be some dust in a optical sensor or the postion sensor switch may be loose and just need repostioning to the correct location. If your not technicaly inclinded I suggest a strong blast of air in this area may solve your dilemma, possibilty hair dryer(NO HEAT), air compressor(max 20 to 40psi) or a good seat of lungs.
SOURCE: turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
SOURCE: My turntable on my kenwood kd-3070 stopped
Is it a belt drive?
If it is then unplug it take the rubber mat off use the holes in the platter to lift it off,then you'll see the belt lieing around somewhere put it back round the edge of the platter then the motor wheele. i'll finish this when u tell me wether or not it's a belt drive.
