Produces ice.. no matter what setting we have on it it will freeze up completely, is on minimum ice cube setting and maximum harvest cycle?
SOURCE: ice sheets too thick to shatter when dropped
timer not working properly replace if necessary
SOURCE: scotsman icemachine m# DCE33A-1WB ice cubes are hollow
Have several of these machines here. The cube size control and the hot gas valve are common problems. I've had several that had one or the other. Generally if the cubes are forming and not harvesting the cube size control is likely the culprit. If no ice is forming then the hot gas valve may be leaking by or several of my machines have had leaks around this valve. The replacement part is not the same as the OEM part.
The charge is tricky and no access valves on this machine. Weighing in the charge is preferred.
Hi Robert Sawaryn, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what is the model number so i can help you with this?
