Question about Kenwood eXcelon KDC-X579 CD Player
Enabling auxiliar cd changer input
I want to connect my ipod through the optional auxiliar input but i don´t know how to enable the AUX in my radio. Thanks!
  • 626 Answers
SOURCE: Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Posted on Sep 14, 2007
  • 626 Answers
SOURCE: switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Posted on Nov 12, 2007
SOURCE: AUX input won't work
The red and white RCA terminals on the back of the unit are generally outputs for amplifiers. To use AUX the unit will need to have a 3.5mm jack in the front or rear. If not than the unit does not have AUX input capabilities.
Posted on Feb 20, 2009
  • 99 Answers
SOURCE: How do I enable the Auxillary option on my
when your car is on, turn the stereo off. you should be able to access a menu somehow when the stereo is off. in that menu, you should have the option to toggle the aux source on or off. simply switch it to on, then turn the sterreo back on, and hit the source button. it should now be ready to go.
Posted on Sep 10, 2009
Testimonial: "Thanks I will give that a try"
  • 2226 Answers
SOURCE: Which button do i push to get the aux sound?
you should be able to access it through the source button.
Posted on Dec 08, 2010
  • 3283 Answers
SOURCE: I hooked up an aux cable to my KDC-MO4028 but the
Hi David,
A decent info page for this radio and options is at Crutchfiled. They seems to provide good / very good information on all the products they sell. Service and pricing is up to you. To use Aux inputs, you need to purchase and connect the optional Aux Input Adapter (picture below).
Crutchfield sells these for about $20, and they plug into the jack on the rear of the radio. The jacks on the cables attached to the radio are preamp outputs - not inputs; and will not work as an input.
Here's a link to the manual (free download). Good luck!
Posted on Oct 02, 2011
0 characters
1 Points
I have a p2500 and its great. Can I connect my red and white audio cord attached to my ipod to the red/white jacks on back of radio? then listen thru aux?
Those cables are for audio out only you need an IP Bus adapter to connect the AUX input. the CDRB20 or CDRB10 is what you need. the CDRB20 allows for more inputs as well such as CD changers, and XM radio tuners.
Mar 13, 2011 | Pioneer DEH-P2500 CD Player
Kenwood Kdc-mp425 will not switch to Aux. Aux cable is connected to the back of the headunit, but no aux option is available on menu for either my ipod touch or my sirius unit. I've accessed the menu from...
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Jun 02, 2010 | Kenwood Sirius KDC-MP425 CD Player
CD changer output not working
There is an obscure setting for 'AUX' on/off that is hard to find unless you know what you're doing or looked in the manual. Typical Pioneer for ya.
Apr 19, 2009 | Pioneer DEH-P3600 CD Player
you have to buy the ipod connection kit to pioneer, but if your deck have RCA input at the back..all you need is Y cable 2 (RCA male - 35mm jack)
RCA will be connected to DECK, 35 mm jack to your ipod.
to use your ipod...change the input setting on your deck to AUX (auxillary) most deck have this for CD Changer connection
Good Luck
Mar 13, 2009 | Pioneer DEH-P6700MP CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Pioneer KEH-P4830R connection to AUX source
Hi. Sorry, I can't actually solve this one for you but was hoping you may be able to look in the manual and let me know which model number CD changers are compatible with this headunit. We don't have the manual and so far have been unable to find the answer anywhere so your help would be much appreciated.
Jan 17, 2009 | Pioneer KEH-P4020 Cassette Player
On the Kenwood models that are within about 6 or 7 years old or newer, there is an iPod adapter for the head units that plugs into the CD Changer port on the back of the radio. Kenwood makes an adapter (KCA-IP500) that gives direct control and charging through the radio and several companies make aux input adapters for Kenwood radios that will connect to the iPod's headphone jack.
Sep 21, 2008 | Kenwood KDC-3024 CD Player
Input/cut out
With the first question, if you are using an ip-bus to RCA adapter to connect your iPod to the CD changer port on the back of the radio, it won't be recognized until you turn on the AUX function on the radio. In the main function menu (usually gotten to when the radio is powered off), there is an option to turn on AUX1 or AUX2. Do this (consult owner's manual) and you should get your audio to play through.
With the 2nd question, the errors may have something to do with the file format on the discs. Not sure though.
Aug 01, 2008 | Pioneer MEH-P5000 MiniDisc Player
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
Switching on the auxiliary input
Best of Luck.
Nov 12, 2007 | Kenwood eXcelon KDC-X579 CD Player
Kenwood eXcelon KDC-X579 CD Player Logo
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
