This thing worked good when i put it away
Could be that your batteries do not have enough mAH? They should be at least 2600mAH. Any thing less than that tends to not have enough power to keep your camera on. I've used rechargeable batteries in the range of 1200mAH and they would not keep the camera on for more than a few seconds.
Try a hard reset by holding the power button down and removing the batteries at the same time, still holding the power button down go back and insert the batteries, it should reset it self in most cases? Another possible problem your camera might have is a stuck barrel lens, if it was dropped or has some sand in the lens gears, that could also make it shut down immediately.
You might try cleaning the battery contacts if it has been in storage for a while. Use steel wool or very fine sandpaper if you can get to them.
