Rival 3040-VG 4-Quart
Problem for Rival 3040-VG 4-Quart
Cooks too hot/fast
By Wendigo on Nov 12, 2007
Not completely sure if this is our model, but I think so. Regardless, since the first use it has cooked very hot and very quickly. The high setting is ridiculous, and even on low it boils and food is done in about four hours. Could there be a problem with the elements or the switch? Thanks!
Same Problem
Sep 03, 2008
-   My Rival even on the low setting ends up boiling - long before the time is up-   Guest
May 25, 2008
-   making ribs...turn dial for simmer..immediately hear a "boiling" sound also,the temp control will turn off and on.. do not remember these 2 things happening before HELP
-   adipose
Mar 28, 2008
-   Rapid Boil on low setting burns food on low setting within 2-3 hours-   mesmerist
Solution #1
posted on Jul 19, 2008
Not Rated)
Lee2fixit
Rank: Guru
Rating: 91%, 221 votes
The Rival model 3040, along with several other models, was recalled due to overheating problems. For details, go to www.rivalrecall.com.
Comments:
Jul 19, 2008
- Correction about the recall... the official reason for the recall was not overheating, but breakage of the handles.
Was this helpful?
Yes
No
Solution #2
posted on Mar 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If the boiling were caused by high altitude, then the food would take more, not less, time to cook. The low atmospheric pressure of the high altitude means that water boils at a lower temperature, so the food wont cook as fast.
Solution #3
posted on Nov 13, 2007
Not Rated)
Moryath
Rank: Master
Rating: 85%, 44 votes
Hi Wendigo,
Crock pots are not exact, they only have a "target" minimum temperature (to be sure they kill bacteria). It's possible you just have a relatively strong heating element.
Also, remember that the boiling point of liquids changes considerably with your altitude, so if you're in a mountainous region you may be seeing "boiling" at a lower temperature than you expect.
Was this helpful?
Yes
No
Popular Solutions for Rival 3040-VG 4-Quart
Questions and Unsolved Problems for Rival 3040-VG 4-Quart
Do you recommend Rival 3040-VG 4-Quart?
Answer
Answer
I have the same thing - brand new crockpot, plugged it in, brushed my hand against it 20 minutes... (More)
Answer
I've lost the instructions for my crockpot and don't know if it needs to be full to a certain level.... (More)
Answer
easy queswtion...my rival slow cooker is about 20 years old...4 quart. Is it acceptable to load... (More)
Answer
I have the Rival Smart Pot model # 5855, is this the same as the Rival 38651? Can I buy a... (More)
Answer
Th control knob on my Rival model 6445 slow cooker has broken in two and I need to replace it
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Crock Pots and... Experts
Top Small Appliance Repairmen
in San Mateo, CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
