Question about LG CHOCOLATE VX8500 Cellular Phone
The sensor for the send key does not work anymore is there a way to fix this
Sensor for send key not working is this repairable
  • 5 more comments
  • Anonymous Nov 17, 2007
    "sensor for send key not working is this repairable"
    I have the same problem. is there any way to fix it?
  • Anonymous Nov 20, 2007
    yep... have been searching the net for an answer too.
  • Anonymous Nov 24, 2007
    i ahve the same problem but not just the send button evrything wow chocolates suck
  • Anonymous Dec 13, 2007
    Same problem here. None of the outside buttons are working along with the send, so not only can I not make calls, I cannot delete things. Annoying!
  • Anonymous Jan 01, 2008
    I am having the same problem everything else works except fo the send key. My husband has the same phone and his keeps on scrolling through all the different menu items without him even touching anything. Anyone else have that problem?
  • Anonymous Jan 08, 2008
    Same problem the sensor for the calling works sometimes. Its funny i will open the phone and it will just start scrolling thru things without me touching anything. It anoying when your phone randomly calls people everytime you open the phone.
  • asang002 Jun 26, 2008
    The sensors on my keypad don't work at all anymore. They used to do the same thing as the other user--scroll through the menu without touching the sensors.
Okay well I have repaired my chocolate many times..
the thumbnail trick does work you can also try pressing down on the send button a with a bit of force what.
whats going on is you had soem water or moister on ur phone. and it seeped down in
the sensor is like aluminum foil with adheisive on it. that is stuck like tape to the front of the phone. it did not move.
the reason for it acting up. is either water has gotten down in it.
but if your send or backspace key simply will not work. but it does not scroll on its own. it means your sensor is faulty.
I do not recoment trying to replace the sensor seeing is its stuck to the front of the phone.
your best bet will be to find a broken phone off of ebay.
and using your mainboard with the the front of the phone you got on ebay.
all your contacts. everything that makes your phone what it is.
is stored on your mainboard
everything else is replaceable you will not lose any data nor will your connection to your wireless carrier be halted.
to disconect the ribbon cable. you have to lift the little brown clamp that runs the with of it. try using a small pointy tipped knife.
be very cautious and sure not to cut your ribbon cable. they sell those on ebay for 3 dollars if you tear it.
once you have lifted the little cable clamp.
simply pull up on the cable. there is a bit of adheisive behind it holding it down just pull sedily and it will come loose. do not use a knife or anything to try to pry it. only pry open the cable clamp lever
also for those of you having white out. or camera problems it is probly because of cable failure.
if anyone can use a screwdriver but would like some help feel free to email me at eekus@hotmail.com
to all the people with chocolates that still seem to be working. please please keep them away from water!!!!
Posted on May 07, 2009
I think this phone is ****, since many of us have the same problem with the sensors. I will never buy a chocolate again..improved or not. Better to stick with a phone that has keys, rather than sensors.
Posted on Jun 26, 2008
The last guest entry was pretty helpful, it actually worked. which leads me to believe that the sensor maybe has moved....i took the phone apart, but i didnt get as far as that chipboard cause i couldnt unhook the cable going to the video screen from the chipboard, but maybe i will try again
Posted on Feb 24, 2008
This is how i used to do it...i would put my thumb nail in between the crack where the send button is...it used to work 4 me...so try it
Posted on Dec 26, 2007
Me too, anyone try to get help from manufacturer or phone server? I hate this phone!!
Posted on Dec 19, 2007
How do I fix a urreal Friends Pax/My Poopin Pup Toy?
No there is no repair facility for toys
Aug 23, 2016 | The Toys
I drove the car in a bad rain storm and now no crank /i heard a noise comng from were the crankshaft position senor is located when the no crank occured
I'm guessing the noise is the starter or starter solenoid trying to work but has a poor connection. Going from what you say about the storm I would be looking in that area for a poor connection of the wiring. The crank sensor wouldn't make any noise.
May 22, 2014 | 2001 Mercedes-Benz S-Class
My xbox 360 console dosnen't read the games anymore! and i just got it on 7/18/10
Yes this is the sensors on the back of the disc drive overheating and to fix it you need to stop this heat build up.
It is not normally the laser that is faulty - you can fix this with a step by step repair guide or you can send it in and they will fix it for you.
Oct 21, 2010 | Microsoft Xbox 360 Console
It wont play games or movies anymore and ALIEN VS. PREDATOR RULES!!!!!
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
If you can stop the heat it will work for you.
Mar 05, 2010 | Microsoft Xbox 360 Console
My xbox 360 is not reading any disks anymore
It is all to do with the sensors on the back of the drive.
Feb 16, 2010 | Microsoft Xbox 360 Console
Lights not working on radio
you will need to send it out for repair, a dealer or a good repair shop will have a place to send your radio for repairs.
Oct 07, 2009 | 2003 Chevrolet Tahoe
CDJ 800 JOG WHEEL IS not working
sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
May 06, 2008 | Pioneer CDJ-800 Turntable
Fuji FinePix S20Pro Digital Camera - Sensor broken
Most likely no. You are probably going to have to send it in for repair or return it to the store.
Feb 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Buttons froze
clean your key pad mat or replace w/ the new one
Jan 24, 2008 | Samsung SGH-E350 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
359 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
