What type of router do you have? Wireless G is the most common and generally has a strong enough output for the typical consumer. Make sure your 360 is communicating with the router and if you still cant pick up a signal then check into a 802.11n Wireless + MIMO. This router has a powerfully expansive reach!
The newer 2.4Ghz or 5Ghz wireless routers should reach a couple of hundred feet. Make sure you do not have your SSID hidden. If you do, you will need to manually enter it into the xbox settings along with other security you have on the router.
