Ricoh 1013f Paper creasing
Hello, I have installed a used 1013f with built-in printer. Printing was originally fine, but over the past few days, all prints coming out get creased. Happens from either paper tray. Any ideas?
  • rciglar Nov 13, 2007
    1.) Creasing after drum - either through the roller unit or fuser assy.
    2.) Everything in place, nothing worn out, (only 19k copies) small piece of paper would not cause crease - but would cause jam. My paper is creasing.
    3.) Replace part - hmmm, which one? The $459 Fuser assembly? I would rather know that is the issue than just randomly replacing parts.
    4.) Has anyone had one of these with a creasing problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1- you need to determine at what point it's creasing
a) when leaving the tray
b) when getting to drum
c) when exiting copier
2- after that you need to see what the problem is,
a) small paper that was torn off causing problem,
b) is the part worn
c) something out of place
3- remove paper or replace part
Posted on Nov 13, 2007
  • CheckitRight
    CheckitRight Nov 14, 2007
    O.K. so you know more or less where it's creasing, if it is creasing from the fuser and it looks good, doesn't mean it is.
    I' ve had many fusers that were not physically worn but were creasing the paper as they came out trough the fuser. Ther reason is because
    1- mylar on pressure roller was gone or bad ( should be shiny and smooth.
    2- upper fuser roller was not smooth.
    3- paper hitting fuser at wrong angle, check ramp
How do I prevent envelopes from getting creased on a Ricoh MP c3500?
Hopefully you are using the bypass when printing them. Creasing is only caused by two things. Moisture in the paper and uneven fusing. Make sure when you are printing them you select thick 2 in the printer properties pull down menu. If the problem continues switch the feed direction and possibly the brand of envelopes. The same thing applies to printing labels (the thick 2 setting will provide the necessary heat to properly fuse the toner). But when copying, push the # key and select thick paper from the menu there.
Nov 21, 2014 | Ricoh Aficio MP C3501 Multifunction Color...
Ricoh Aficio 1013F MFP bottom tray paper senser broke off. Where can I get a replacment?
Remove the actuator and try using super glue or adapted a little part of ABS.
Feb 16, 2013 | Ricoh Aficio 1013F Copier
Ricoh 1018 Fuser finger pickups malfunction. I acquired one upper pickup finger for the fuser drum/roller and two new springs. All were missing after a jamb. The new pieces have been installed and the...
Hello!
Assuming that the fuser "fingers" are well assembled you need to see if the fit is ok. It happenes all the time that this fit is broken and can not holds the "fingers"
Sep 10, 2011 | Ricoh Aficio 1013F Copier
I have option to buy ricoh 1013F copier i need it to be wireless
If you already have wireless setup easiest way is to purchase a wireless bridge, gives you wireless connection with hard wired port to connect to the copier. Configure the bridge to same wireless settings as your network and plug cat5 cable from machine to bridge setup print driver and you are golden,
Hope this helps,
TankMurdock
Apr 23, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
How do I stop information page from printing out?
(Reports on/off)-Key operator tools,user parameter,switch03,bits 0 and 5 set to 0.That should do it.
Jun 17, 2008 | Ricoh Aficio 1013F Copier
Printing faint lines with fine corresponding creases on drum
You probably can not repair it. I will say this though, be careful to get the right labels for it.
Mar 02, 2008 | Ricoh Aficio CL1000N Printer
Ricoh 1013f with optional 2nd tray
You have to set it through the menu button, just scroll through the options.
Dec 21, 2007 | Ricoh Aficio 1013F Copier
188 people viewed this question
k24674
jasbo
jasbo
