Question about JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 problem
When I turn the power on, the power light will come on but no picture and it will start to blink. It will not turn off even if I press the power botton. I have to unplug to turn it off.Thanks
I am not sure of the part number, but I had this problem with mine a few years ago, it involves replacement of a 4 inch square board (mine has the number LCA90059 on it with the words CRT SKT PB ***'Y on it) 2 wires coming from it (one 6 wire group with white plug ins on each end, and one 4 wire group with white plug ins on each end) and a large white plastic turbine looking thing (non moving) in the center with a yellow plug on one side of the top, along with a silver 2 in long by 1 in high heat sink on it with the letter B on the opposite side of it. Hope that helps! I noticed its been posted a while, but maybe this info will help someone else.
I am having Red Convergence problems with mine which is what prompted me here ,,, it will not work in auto convergence, and when I manually do it, the red will not move left or right, only up and down.
Anyway, good luck!
Posted on Mar 20, 2008
JVC AV-65WP74 turns on and blue power light flashes fast but no picture and no sound
Jan 30, 2014 | Panasonic PT-47WX49 47" Rear Projection...
Flashing green power light
If the model indicated here is right It could be in the power supply and this model sometimes fails where light just blinks--that could be also convergence issue--in this model there is a way to disconnect the power going to the convergence board to see if set will then turn on.
Jun 14, 2012 | JVC AV-65WP74 Rear Projection Television
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 clicks and sounds like a heart beating and then turns off. what is the problem, how much will a repair cost?
it could either be convergence ics shorted or deflection board trouble
as to cost convergence 300 to 350
if its power supply 300.400
it would have to be isolated down to the exact location causing the problem
but usualy a great set to keep around
Oct 24, 2009 | JVC AV-65WP74 Rear Projection Television
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
No picture
have the power supply checked out
Sep 09, 2008 | JVC AV-65WP74 Rear Projection Television
You can get eplacement CRTs ( picture tubes ) for your model at the following link.
Aug 09, 2008 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 Rear Projection Television Logo
78 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
