Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven won't light
GE XL 44
The broiler works fine but the oven won't. Any suggestions? Thanx!
  • Anonymous Jul 29, 2008
    How to change igniter?
  • 248 Answers
Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
Posted on Nov 12, 2007
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
We have a GE XL 44. The oven won't heat up at
sounds like a bad control panel , I bet it is a touch button type if it is get all the info off unit and order control panel here http://www.appliancepartspros.com/
Jul 27, 2011 | GE Ovens
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL 44 gas oven not working. I replaced the igniter for the oven, but not the one for the broiler. Also replaced the regulator valve. Still doesn't work. I didn't replace the broiler igniter as we...
most newer models of gas oven require electricity in order to work. I would check the outlet where you have your oven plugged in. Plug something else into that outlet to make sure it is live. If it is not, check the electrical panel breaker or fuse.
Oct 29, 2009 | Kitchen Ranges
GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
When turn oven on GE XL 44 Gas Stove bottom of oven does not get hot. However there is an orange glow coming from bottom of oven under the shield. What do you think it could be? Broiler works fine. Thanks...
The glow that you see is the electronic ignitor. If it is glowing and not getting hot you will need to replace the ignitor. It is not strong enough to open the gas valve. They grow weak over time.
Apr 26, 2008 | Kitchen Ranges
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
237 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
