Question about Dell DJ MP3 Player
Make vista recognize my dell dj 20 gig
I have windows vista. i have a dell dj 20 gig mp3. windows media will not recognize my mp3. help. also when i downloaded the software that came with my mp3, windows is not compatible. help!!!!
Re: make vista recognize my dell dj 20 gig
Try downloading the newest firmware to your Dell DJ
Posted on Jul 08, 2008
I had a similar problem when I had to reload my Windows XP. The MusicMatch wouldn't recogzine my Dell DJ and I couldn't locate any plugins. I ended up on the Dell website and downloaded a copy of Dell DJ Explorer. This program uses Windows Explorer to manage the songs, playlists, etc. I used it on my Dell Pocket DJ (5 gb) and it worked fine (after a short learning curve).
Posted on Feb 03, 2009
Weet iemant
Posted on Jul 16, 2008
0 characters
3 Points
Running windows 7 home on one PC and windows 10 on another. I don't have the installation disc anymore, and the drivers I downloaded from Dell don't seem to work.
Daisy Mae,
The Pocket DJ is not compatible with Windows 7 or Windows 10. If you plugged it into your computer and it did not recognize the device or show up in "My Computer' then it will not work. You would need a windows 7 and Windows 10 drivers.None are available..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 01, 2016 | Dell Pocket DJ MP3 Player
I have a discontinued dell pocket dj player that when i download the software it says it isnt compadable how do i fix this i have a vista.
Go to and enter the DJ's service tag ID on the back of your player on the support section. It will give you a list of drivers and software that you will need for your DJ. If you are running Vista, download the XP drivers. They will work fine.
Oct 09, 2009 | Dell DJ MP3 Player
HOw do i install the dell software dor my Dell DJ 1.00.03 on Windows Vista
Oct 09, 2009 | Dell Pocket DJ MP3 Player
Dell DJ 30gb not recognized in vista
try using a different usb cord and u can also use songbird to put songs on it
Aug 16, 2009 | Dell DJ MP3 Player
How do I download music from my comp to my dell dj pocket?
If you haven't tried yet, just plug it in.
Vista is loaded with drivers and it should be able to find one for your DJ.
I hope this helps.
Jul 13, 2009 | Dell Pocket DJ MP3 Player
Cannot get my computer to recognize my Dell Jukebox
Assuming that you don't have windows vista, you can load the Dell DJ Explorer program that came with your DJ. It comes up as a regular looking window that should "see" your DJ when you plug it in. If it doesn't, where it says "not connected", right click and then click refresh. Sometimes it works better to plug in the DJ first, then load dj explorer. When it sees it, "not connected" should change to the name of your DJ. Double click that and it should then 'read' your dj, showing all the files on it. Then its just a tedious amount of copy and paste to another folder on your computer (like your My Music folder), and your music is restored to your computer. Take care, as DJ Explorer can also delete files from your DJ if you tell it to.
If you no longer have the DJ drivers and DJ Explorer and Musicmatch loaded on your computer, you can still download that stuff from the Dell site.
If you Do have Vista, try to find a friend with XP. Load the DJ explorer software on their computer, and pull your music off the dj to your friend's computer, then use a USB drive or something to move it to yours. Or better yet, upgrade your computer from VIsta to Xp (yes, I said upgrade - Vista is ****)
Jan 28, 2009 | Dell DJ MP3 Player
Why dell dj 20 wont work w/ win vista
additional software/add-on required? i have Gen1 and win7. is this possible?
Oct 18, 2008 | Dell DJ MP3 Player
Frozen and my comp wont recognize my dj
Hold pause down, press reset button with paperclip (in the little hole on left side), then choose clean up, then select reboot. It will reload your library and it wont erase your files try it, I did and it worked fine after that.
Sep 16, 2008 | Dell DJ MP3 Player
Dell DJ (Generation 2) not being recognized by computer
Found the answer on Dell Forums. A lot of Dell DJ folks have been having the same issues. The problem is with Windows Media Player (shock). The Windows driver dated 2006 is installing itself and taking over, not allowing Dell's 2005 driver to work. The bottom line is the DJ will dock but not be recognized by your computer, Windows Media Player, or Yahoo Music Jukebox.
To check to see if this is the issue dock your DJ then click on start, right click on my computer, and then hit properties. Click on hardware tab and go to device manager. Look for portable devices on the list. You will likely see your DJ with a yellow (!) next to it. Right click on the DJ and hit properties again, then look in the driver tab to see what driver is listed. If you see a driver with the date 2006 or newer, then Windows is screwing you up.
The only way I've found to fix this is to either uninstall Windows Media Player or go back to an old enough version that the 2006 driver is not in the system. The 2006 driver is from Microsoft and somehow it interfers with the proper driver, which is from Dell and should be dated either 2004 or 2005. Once Windows is uninstalled completely, or back to an old enough version that you are safe (I am not sure how far back you must go, I just uninstalled the darn thing completely), you need to uninstall the Dell driver then go to Dell's website and reinstall the latest. Also make sure you have the latest firmware.
It sounds like a lot of work but it honestly took me longer to type this note that to do it and I don't have a clue what I'm doing. It's better than throwing away your DJ. From the comments I saw on the Dell Forum, Dell is not aware of the issue and isn't much help. Many people spent hours on the phone with Dell support only to hit a dead end and get the recommendation to replace the device.
Hope this helps all. A huge thank you to the folks over all Dell Forum who figured out the solution despite Dell's technical assistance.
Apr 22, 2008 | Dell DJ MP3 Player
go to the dell website, download the driver for windows XP, before installing the driver right click on the install icon, go to properties, securities and select "Run as Administrator". Now install the driver. This should allow you to run your driver and software. I have the 30 gig and it worked for me. good luck and I hope this helps.
Oct 29, 2007 | Dell Pocket DJ MP3 Player
Dell DJ MP3 Player Logo
1,452 people viewed this question
Top Dell MP3 & Digital Media Players Experts
Level 1 Expert
Level 1 Expert
Are you a Dell MP3 and Digital Media Player Expert? Answer questions, earn points and help others
