SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: Wire feed not working Miller 250 mig welder
If the knob spins all the way around (and especially of it didn't always do that), it's broken. This could mean that the nut that holds the rheostat in place has come loose, or it could be that the wiper inside the rheostat has broken off the shaft. To find the voltage measurements, correct schematics, etc, I'd need to know the serial number of your welder.
Regards,
Carl
SOURCE: Miller 130 XP wire feed quit working, fan runs....
Usually either the Power Supply to, or, the Motor drive circuitry. Or even the "Feed motor" itself.
SOURCE: miller 175 trigger will not feed wire very
First thing make sure the lead cable is as straight as possible. and make sure the wire has a unobstructed path. then you should check the trigger input/output switch and see if the switch is getting power to it continuously. I hope this help please rate this thank you
SOURCE: Miller mig welder #175 stopped
This usually happens when the main Power semiconductors fail. You need to check out the two main places, the Power Supply, make sure ALL voltages are correct, and the main Output semiconductors, check these to make sure they are Not open circuit or short circuit.
http://www.millerwelds.com/service/ownersmanuals.php
Above is your support link.
You need to contact Miller and obtain a service manual, before attempting to service this unit.
