GPS Logo
Posted on Nov 12, 2007
Magellan Roadmate I have reformatted the Internal Memory the GPS Receiver now does not have sound, language settings, and maps. I need to re-install the files of the Magellan Roadmate 360 Manager Software Program (that is not included in the box). I have asked assistance to Magellan, but they just want me to send them the Unit for repair, while the Unit is working, and it needs only to re-install the software on it. Can you help me to locate such software for download?
  • 2 more comments
  • masduro Dec 07, 2007
    i have the same problem can i get softwear to
  • svandre Mar 30, 2008
    I reformated 3% of the internal memory on my roadmate 360 and now it has no sound. It works fine bun no voice...
    What can i do? does anyone have the files i need to fix it?
  • Anonymous Apr 13, 2008
    I have the same Problem?
  • Anonymous May 16, 2008
    I DONT WANT TO THOW IT AWAY I NEED HELP SOFTWARE
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
316
Points
0
Same problem. I finally threw it away and bought another brand GPS
2helpful
2answers
Magellan roadmate 1412 just stop working and displayed the following messange: "SD card has been removed. Program will restart. Please insert SD Card with map"
Providing you saved the SD card info as soon as you got it, reformat the SD card and copy the files over. Or find a friend that has the same unit and copy their files. Reformat your card before also.
I reformatted my roadmate 300 & now it says no maps found & I have no sound. What can I do?
you didnt back up the drivers and map?
well you will have to reinstall them now from the CD that came with the unit If you dont have one proof of purchase is required to get one
My internal memory is ereased
of course get to ur manufacturer page and look for download center
or u might need to upgrade it from there
1helpful
Help me please
I had the same problem caused by reformatting the internal memory and this is what I did which worked for me:
Make sure you remove any SD memory cards before trying this fix.
First: find the base maps (NA_BSMAP.mgi and NA_BSMAP.nlt)maps which are located in your computer in the Magellan Roadmate Manager (C:\ProgramFiles\Magellan\Magellan RoadMate Manager NA\Map\Basemaps)
Second: Connect your Roadmate with the USB cable to your computer.
Third: Plug in USB and power up your GPS. Cut and paste the two files mentioned above to your GPS (Devices with Removable Storage (example E:/). They are approximately 25 MB in size and will take a few minutes to copy.
Fourth: Unplug the USB cable and shut power off to the GPS.
Fifth: Power up the GPS and it should find the "base maps".
Good luck!!
Magellan RoadMate 360
https://www.magellangps.com/support/
select: Product Support & Updates
select your unit and download firmware update for you unit
Magellan 300 Roadmate
I think you are going to struggle here.
It may be possible to put the sounds back using the Magellan RoadMate PC application it is mentioned in the manual and on the web site http://www.magellangps.com/ but I cant see where to obtain it!
You are not alone, there is a thread here with people complaining about their receiver and trying to find the software. http://www.expansys.com/ft.aspx?k=63844
A reviewer here is actually using the software http://www.gpsinformation.us/rm300/Magellan%20RM300%20map%20loading.html note the red warning about formatting the internal memory!
I checked P2P to see if the software was floating around but all I found were maps.
Sorry for all the links but I think you'd better be informed that this ain't a quick fix and contacting Magellan may be the only way.
2helpful
5answers
Magellan Roadmate 360 Manager Software Program, and Preloaded SD Card
Hi guyz I pretty much did the same thing!!! I bought this gps for my girlfriend for valentines from a friend and i was trying to restore it to its factory default and the only option i found was repair and i did an internal memory format like a ****! well everything seems to be fine but no audio at all! I've done lots of research and it seems to be that the only way to fix it is by restoring the sounds files but where can i get them? I MEAN magellan doesn't provide any support any more due to the unit is discontinued! I mean how messed up is that? AND why would they provide with such a horrible option? that's sad! Can anyone please please please help me? please I'm going crazy here! :(
2answers
No maps found!!
Hi - I have the same model GPS but I've been unable to locate a copy of the CDs and I'd love to get a copy of them - would that be possible? My email address is [email protected].
As far as re-installing he maps, here's what I've found. I think this might help:
Locate the files that are loaded on the computer.Magellan Roadmate Manager example: C:\Program Files\Magellan\Magellan RoadMate Manager NA\Map\Basemaps
Copy all files. Make sure your Roadmate is connected and click on Example E:/Removable Disk and paste them with other files. It takes a few seconds to 1 minute to transfer the 25.5 mb file so don't unplug it until it is finished.
1helpful
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
