Back to:
Tags:
Gateway CX200X Tablet PC
No power up (by 3 users)
posted by skyflyrr on Nov 12, 2007
My CX200X w/2.xx Gig stopped operating yesterday. No power up, no LED's with AC charger, no LED's when power button pressed, nothing at all. AC charger has voltage. Out of warrenty of course.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Maelwys, posted on May 01, 2008
So I picked up a multimeter and disassembled the laptop last night.
1st, I confirmed that the power cable is live, which it is.
2nd, I confirmed that the power jack is live (when the cable is plugged in, the internal contacts are live), which it is.
3rd, I confirmed that the contacts to the motherboard are live (when the cable is plugged in, the soldered contacts on the opposite side of the board are live), which they are.
So, I can confirm that power is getting into the motherboard without any problems. And the jack is still very secure on the board (since I know a lose jack is a common problem). Unfortunately, once the power disappears into the board, I've no way to trace where it's going. And no matter how hard I look and how many helpful sites I find, none of them have a repair manual or schematics manual for this model of computer. I couldn't even find one to tell me how to get it apart, had to rely on eyesight and intuition to figure out that part. ;-)
So, can anybody give me any hints where else I can look for the problem? Visual inspection reveals no clearly fried circuits, but that doesn't mean they don't exist. And the battery contact is like 7 pins, and I can't tell where on there is supposed to be + or -, so I don't want to start sticking my multimeter anywhere that I don't know what the flow is. ;-)
Any hints would be appreciated, thanks!
Comment by Maelwys, posted on Apr 30, 2008
I've had the exact same issue. Confirmed power is getting to the jack, but no battery lights, no 'plugged in' indicator, and it doesn't turn on. Definitely not a power-lock problem, since the lights would still be on in that case, at least.
Best Solution
posted on Dec 07, 2007
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Are you sure that the lock button is completely in the unlocked position? If so, once this happened to me, and I removed the battery for about 5 minutes, then reconnected it and the computer powered up.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no power up:
I don't want to Accept this solution
Can you Help with these Tablet PCs problems?
I need to have my backlight replaced on my gateway CX200X....
pc turns off when placed in tablet mode or straightened...
i uses to connectivity on my gateway pc like at the...
We have a family laptop HP Entertainment Pavillion. It has...
We have an abused CX200X to repair. One of the cables that...
Loading problems.
Repair Service
Find Tablet PC Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
