Question about JVC AV-56WP30 56" Rear Projection Television
JVC I'Art. 65" projection TV. AV-65WP74 green screen sages real low.
I am experiencing a proble with the green convergence. I think.
At top of the screen the green color sages and the red shows well.
When i remove the green optic tub the pic is fine, but has no green in the picture.
  • 1 more comment
  • jren Jan 07, 2008
    have the same problem on a 56" model. seems sort of common as I found several references online to similar issues. I have the ablitiy to R&R the chip. Own my own solder iron and a sucker and wic...Where can i get the chips?
    thanks.
  • Anonymous Jan 06, 2009
    I have the same problem and found that problem is becasue of the resistors which needs to be replaced. This will cost me $300 to fix.
  • b_conder Feb 04, 2009
    Having issues with the convergence on a 56" TV. I just had my brother-in-law replace the convergence ICs, but am not certain as to where the feed resistors are located, to replace them. The ICs did not resolve the issue, so I am hoping the replacement of the resistors will. The ICs were removed from a Pioneer television (PNs were checked to assure appropriate parts were installed.) The Pioneer did not have issues with convergence. What are the Resistor numbers, if available, from the schematic, and about where, on the system board, are they located? Thanks
    Problem Solver:
  • 16 Answers
You have bad convergence ic and or resistors
this repair usually requires a repair tech
Posted on Dec 27, 2007
  • 4 Answers
I had the same problem that required a $400 technician fix. 1st time i tracked it to a $0.05 resistor blown. could not find in radio shack... was due to bad "brain".
Posted on Dec 04, 2008
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
My jvc model# av-65wp74 the screen is bowed and the colors will not match up.i have put in two new convergence chips still no luck.
did you check the low ohm resistors. A JVC will almost always blow at least one and if the ICs are replaced without replacing the resistors the new ICs will fail instantly
Feb 26, 2011 | JVC AV-65WP74 Rear Projection Television
Blue lines arc down from the top of the screen on JVC IART TV model number AV-65WP74. Is it worth fixing? Thanks
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
May 13, 2010 | JVC AV-65WP74 Rear Projection Television
I turned it on today and it has a green haze on the screen.
Convergence is dead.Must change convergence ICS and all it resistors.Know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepair.com to repair it ur self.Shop well cost u $300 for parts and labors.
Jan 23, 2010 | JVC AV-65WP74 Rear Projection Television
The TV has just started a red/green problem. The picture is double in the top and bottom of the screen with one image red and the other green.
you need to install a convergence repair kit. The AV48WP74-AV65wp74 convergence repair kit from www.tvrepairworld.com has the parts and the CD with instructions.
Dec 11, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
Hi, sounds like your convergence IC`s have failed if one of the colors doesn`t adjust either up/down
or left/right. If you have soldering equipment and are very proficient at soldering you can replace them. if not you definitely need to call a tv tech, if you need more info ask away, video-tek
Jan 26, 2009 | JVC AV-65WP74 Rear Projection Television
JVC 65 inch projection tv
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Nov 29, 2007 | JVC AV-65WP55 65" Rear Projection...
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-56WP30 56" Rear Projection Television Logo
605 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
