Question about HP LaserJet 3052 All-In-One Printer
Please insert your originals into the automatic document feeder hp 3052
HP LaserJet 3052 All-In-One Printer how to resolve operating system win 7 32 home basic
    Habit-Forming:
    New Friend:
  • 56 Answers
It is looking for a document to scan. Either a copy job was started and interrupted or the device is not sensing a document in the adf. If scanning, ensure document is flushed and is fully inserted. If not scanning, cancel all jobs. If scanning and document is flush and fully inserted, check sensor/flag which may need replacement if all else is good.
Posted on Feb 22, 2015
SOURCE:
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
Posted on Feb 10, 2008
  • 105 Answers
SOURCE: HP laserjet 3055 has Document feeder jam errror
It sounds to me like the switch that senses when paper is present is blocked or out of position.
The User Manual and such does not provide sufficient detail for me to decipher what type of switch is used. It is either going to be a switch that is depressed to close the circuit when paper is present and is held down somehow now, or it is a proximity sensor and there is dirt or whatever on the sensor that is enough to make it think there is paper there. It should be something that appears to be a tiny window, and it would need to be cleaned with a qtip or 100% cotton cloth and isopropyl alcohol.
You will likely need to remove the ADF feeder cover to obtain full access to the ADF mechanism and find the sensor, since it is most likely recessed in the ADF quite a ways.
The other possibility is that the wire for the sensor has been damaged after a jam or something of that nature.
If you have searched for the sensor and cannot locate it / clear the error, then you will need to have a service tech work on the machine.
Posted on Jun 20, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    trlinde
    • 20 Answers
    SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
    Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
    Posted on Jun 18, 2009
    SOURCE: My Printer HP 1600 Laserjet error 10.1001
    Did you fix your problem? I have the same one. With Hp 2600N
    All cartridge are new, and i removed the orange tab from each one.
    I even tryed a second new cyan.
    Did you remove All the orange tab from cartridge?
    Posted on Feb 12, 2010
    Download driver hp laserjet 3052
    go to www.hp.com
    click on support and Drivers, choose u r Operating System and downloaded it.
    Nov 03, 2013 | HP LaserJet 3052 All-In-One Printer
    Try holding the table top lid down gently while you feed it into the document feeder. It may be that it is not reading the top as closed to defer to the feeder.
    Jan 02, 2012 | HP LaserJet 3055 All-In-One Printer
    HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
    Hello Steve !
    The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
    So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
    Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
    Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
    Now just hit "Start Copy" and it print LEGAL ! it worked for me
    Hope this help !
    You can contact me at:
    [email protected]
    Bryan
    Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
    When trying to copy papers do not feed but if you scan they will
    HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
    • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
    2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
    3. Close the ADF cover plate.
    • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
    1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
    2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
    3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
    4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
    5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
    6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
    7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
    9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
    Have a good day
    Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
    I lost my instalation cd for hp laserjet 3052 printer how to install my printer
    1. Go to support.hp.com
    2. In the "Enter your product number" area, typ in LaserJet 3052, or whichever model your printer is. I was confused because in your question you also mentioned the p1008. Either way, just enter in the model name.
    3. Under "Tasks for HP LaserJet 3052 Printer", the first thing is download drivers and software. Choose that.
    4. Then, select your language and operating system. If you're not sure what operating system you have, right click on "my Computer" that is on your desktop, and go to properties. The general tab contains the information about what operating system you have.
    5. Then, go to the "Quick Jumps to download by category" and choose "Driver"
    6. In my humble opinion, I always pick the driver at the top of the list, because it is most updated.
    7. Click the download button.
    8. In the popup window, choose run.
    9. This should start the installation process.
    May 30, 2009 | HP xw4600 Workstation Linux Installer...
    Unable to install the printer
    if you want to install Laserjet 3052 All in One Printer
    then you can download the drivers from the below link
    Choose appropriate Operating System according to your PC or notebook
    Download HP Laserjet 3052 AIO Driver
    after download the file, double click to run the setup
    and do as directed to install your printer
    Remember : just turn your Printer and Do NOT connect USB cable to PC. Connect only when directed by Setup
    All the best
    Jan 05, 2009 | HP LaserJet 3052 All-In-One Printer
    HP 3055 model scaner problem
    Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
    Paper jam in the automatic document feeder
    I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
    Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
    HP LaserJet 3052 All-In-One Printer Logo
    288 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
