Question about APC AIS 3000 UPS System
  • C-ray Van Nov 12, 2007
    i need an advice.
    New Friend:
  • 159 Answers
Disconnect the load on the UPS tray to turn the UPS on if the problem still there is a faulty on the controller board
Posted on Apr 05, 2008
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Status : inverter overload - appear / MGE Galaxy 5000
maybe 1 of the three output phases is overloaded please check and distribute the load correctly on the output phases
Jan 23, 2014 | MGE Computers & Internet
Compaq presario b1900 fails to give output to monitor. If output comes out it gives blue screen and shuts down. If you switch on again the fan and disk do run but no output to screen. An external monitor...
That blue screen and shut down, means a problem on both OS and Hardisk.
If you got any hardisk for that laptop. try it and am sure it will work.
The faint beep means a good memory card.
Hope that helps!
Dec 02, 2011 | Compaq Computers & Internet
Mi Ipod was playing thru the VCR 2 output via an rca>1/8 inch jack. No longer get any sound from that or the VCR 1 output. Phono output gives sound with an overloaded bass. Is the receiver shot? ...
You don't say if the iPod still works with any other Line level >>>> INPUT <<<<. There are 8 of them.
Do you have any other devices to test the VCR1 and -2?
Feb 14, 2011 | Denon AVR-1801 Receiver
I just moved and my washer through the error code "sud" when it started to spin it wont drain either.
You have either overloaded the machine, or you have used too much soap. unplug washer for about 10 minutes. set to rinse and spin, should work fine. If you cant get it to work tried putting some veggetable oil to kill the suds.
Nov 30, 2010 | Maytag EPIC MFW9700S Front Load Washer
I have a UPS 1000 VA with 12 V X 2 Battery, Problems: when we on ups input 200 V without load, it gives output 210 V. when load it gives 230 V on electricity. When Electricity cut off it gives 250 V. When...
arif qc, Are you using a DMM that is or will make "true RMS" measurements or is it an "average responding" type of voltmeter? Is this APC ups designed for 120 vac input/output or is this unit a 220 vac input/output type? Use only a "TRUE RMS" type DMM to make your measurements!!! I believe if you visit Tripp-Lite site, you will find a tutorial video clip of why you should use a true-rms meter to make measurements of output voltages. 12fixlouie
Sep 07, 2010 | APC Smart-UPS 1000VA UPS System
Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Aug 30, 2010 | Kitchen Ranges
Cant see snc rz30n, appear ip ip setup window, won't load page
Enable network and then give ip in the address bar of browser the home page will be browse.
Jul 11, 2009 | Sony SNC-RZ30N Network Camera
Dynex TE685AVR - wiring problem light on
yes first disconnect the pin of load then switch off ups then switch on check ac voltage at output if comes and disappears when load is connected then battery is faulty it shows voltage without load but disappers when load is connected replace battery
Nov 09, 2008 | Dynex (TE685AVR) UPS System
No sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
Sep 13, 2008 | Audio Players & Recorders
APC AIS 3000 UPS System Logo
132 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
