Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Won't wash, just sits there and electonic buzz noise
This unit is only 15 months old and has been used probably ONLY 50 times.
there was a smell of burning plastic like something overheating, could not find anything.
lost manual, so no clue on how to troubleshoot issue
Went online, found out the gaskets can stick
removed bottom shroud from front, tilted machine for access, used pliers to turn shaft on motor to free it up.
works fine.
now i turn it on every week, just to keep it from sticking again
Posted on Dec 13, 2007
  • 126 Answers
Check around the element.if you have calcium build up on your element it will smell too
Panasonic PT-56LCX66 buzzing noise when i push power
I'm going to take a guess and say that the buzzing noise and burning smell was either a transformer or a blown capacitor (more likely). It's likely that your old lamp was still good and there is a problem at the circuit level.
If you or someone you know is comfortable with electronics, you may want to open it up and take a look. If there is a blown capacitor it will be obvious. Take a look at badcaps.net or Youtube for help on identifying them.
If you don't feel comfortable working on the inside of a TV it's probably time to get a new one. Repairs will not be cheap and they won't be worth it.
Jul 24, 2012 | Panasonic PT-56LCX66 56" HDTV
John Deere LA145...it will fire up and immediately die and then won't start again. What should I do?
Usually this symptom means a clogged filter, gas tank outlet tube is plugged or a clogged needle valve. But if it smells gassy it is probably not starving, but may be running too rich. If it does not smell gassy then it's probably a fuel delivery problem. Sometime rubber fuel hoses can swell up inside and restrict flow.
Apr 14, 2012 | Garden
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
May 03, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
After about 2 weeks of use, the microwave began to make a horrible buzzing noise from the "box" in the upper right hand corner on the back. It also smelled horrible. It then proceeded to stop working...
Two weeks? This is a warranty problem. The buzzing noise was probably either from high-voltage arcing or an overloaded transformer trying to drive a shorted component. The smell is from something electrical getting fried. Remember it; the next time you smell it, you'll know to pull the plug.
Oct 12, 2010 | Sunbeam SMW777 Microwave Oven
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
RCA dlp 50"
Buzzing is usually indicating the color wheel is defective. Or it could also be the lamp fan malfunctioning as well. My quess would be the color wheel as thats a fast moving part which is prone for bearing failure.
Aug 03, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
164 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
