I can't set anything on the control panel. This error keeps popping up. It will not sew at all. I have only used this machine once. It has been put up and now I take it down and it won't sew, I can't set the panel to anything. It is showing a C and then another C facing it backward. It is a C not [
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
SOURCE: My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
SOURCE: the needle will not go all the way down to start
Do not turn it backwards because you will mess up the timing, which may already be the case. I would try taking out the bobbin completely and unthreading and see if it turns then. If not, you may have to take it in for service.
