Question about Dell Latitude D600 Notebook
Can I fix this???
My Dell Ispirion 600m has a broken pin where the charger connects.... I believe they said it was connected to the motherboard??? Anyways.... they want alot to fix this... is this hard to fix? can I do this ?? I plug in the charger to the wall and the light goes off on the charger cord as soon as its connected to the device. Any Ideas???
  • 59 Answers
if that is the case, then there is indeed a short on the ac port (thats where you plug in the charger.) that's the reason why the charger light goes off as soon as you plug it in to the back of the computer. I know its gonna cost you a lot since the only way if fixing this is to replace the motherboard. if its gonna cost you $500 + then better buy a new one. they're gonna replace it with a refurbished motherboard anyways.
Hope this helps.
Posted on Nov 12, 2007
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
The ac port in my dell inspiron is broken so the charger pin isn't connecting to it and the laptop wont turn on because the battery is dead and i cant bother to buy a new solder cause im not from
A) You don't want to take the laptop apart.
B) You don't have the money to have it repaired.
C) Keep going like you are with fiddling with it, and you'll smoke the AC adapter (Charger), and Power MOSFET's on the motherboard.
What !O_O! sort of 'miracle cure' are you expecting?
If you wish to correctly repair the laptop, this is the place.
Rig it so it works temporarily, and maybe permanently damages it?
Suggest go to another website.
Charger Board
You're going to need one of these, and connect it's alligator clip to a good ground source,
Doesn't have to be from that store. It's just an example.
Average cost is $3 to $6.
Need guidance? I'm right here. Post back in a Comment.
I'll step by step you through it.
Mar 01, 2013 | Dell Inspiron 15 1545 Notebook
vga cable out the back of the dell to vga input on tv,,or jus use s video out if dell has it,
Nov 03, 2010 | Dell Inspiron 6400 Notebook
Will Not charge with brand new a/ power cord it will at times power on if moved the right way but quickly powers off if moved the port inside looks to be fine But I hear there is a pin type thing inside...
The problem is with the AC adapter itself and is a very common problem with Dell AC adapters. My suggestion would be to get an aftermarket AC adapter that can be purchased on eBay as the Dell adapter is around 100.00. You can pick up an aftermarket one on eBay for around 20.00. The problem is a resistor inside the AC adapter that senses when a Dell branded adapter is inserted. What happens is that the resistor will get damaged and since it doesn't recognize the charger as a Dell branded one anymore it won't charge. However it will still run the laptop as long as it's connected. A lot of aftermarket AC adapters bypass this function and work perfectly fine.
May 29, 2010 | Dell (04U621) for Latitude D600, Inspiron...
Battery will not hold charge new battery lasted 1 month and shorts out the charger
I would open it and look to see if the DC jack is damaged. It could be arcing to another connection.
Apr 25, 2010 | Dell (04U621) for Latitude D600, Inspiron...
When i press the power button the laptop is not on
1.Remove the Baterry
2.Long press the On/Off button (around 20 seconds)
3.Then connect the charger
4.put on the charger
5.after 5 Hours Put on laptop
Feb 11, 2010 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
Laptop will not turn on when i press the on
Normally, if the LCDs light momentarily and go off, then the system is not getting power from the AC adapter (Even if the light is on on the brick)
  1. If another Dell D-Series AC adapter is available, try it. if not check the output for the plug to the system for 19 volts DC, if no voltage, replace the adapter.
  2. Check the connection on the system for cracks or loose connection to the motherboard. If the connector is damaged, then the jack or the motherboard will need replacement
  3. If the system will not power on with a known good battery or AC adapter, then try these steps.
Dec 25, 2009 | Computers & Internet
Battery not recognized Pavillion zx5000
A $150 dollar or so MB on EBay should resolve the issue. I know this is a pain, but there is an apparent issue in the charger curcuit
Sep 02, 2009 | Dell Inspiron™ 600M PC Notebook
Dell inspiron 600m sound drivers
Hi the easyest place to find all your drivers for your Laptop is to go to the Dell website.
here is a link to your model of Laptop Dell 600m
Nov 08, 2008 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Dell Latitude D600 Notebook Logo
123 people viewed this question
Alun Cox
