Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 cd/dvd drive
Our exchange student tried to burn a CD and the drive is now stuck. We can't get the CD out. Any ideas??
  • 324 Answers
Re: Dell dimension 5100 cd/dvd drive
There should be a tiny hole on the faceplate of the CD drive. If you straighten out a paperclip and insert it into this hole and press in, it should allow the CD to be manually ejected. After doing this, press the eject button and see if that makes the CD drawer go in and out.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating.
Thanks you, and have a super day!
Posted on Nov 12, 2007
0 characters
3 Points
Can't burn CD
it's probably your CD drive, or do you need to figure out how to burn from itunes. if anything you need to update your driver
Jul 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My dell dimension 5100 will not read CD's
If you have already cleaned the CD lens with a lens cleaner, just replace the drive with a new DVD writer.
Good Luck
Dec 27, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
CD Mechanically stuck in Drive Dell Studio 17
turn on the PC and insert a pin in the small hole on CD will be ejected.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My dell dimension 1100 dvd/cd drive tells me that the drive is not installed how do i go about re-installing it or getting it to read stuff, problem occurred after i had gotten it fixed from viruses etc...
Reinstall the DVD/CD drive software: Control Panel - System - Device Manager ... find the DVD/CD drive and right-click to remove or reinstall. Then, restart your PC. Good luck.
Jun 13, 2009 | Dell Dimension 1100 PC Desktop
The cd is stuck in the lapptop, it does not come out when i press eject button. Dell xps M1530
Hi there.
Get a large paperclip and straighten it out.
It the CD/DVD has a flap that drops down, pull that down.
Look very close at CD/DVD you will a very small hole on the face of the CD/DVD (usually near the eject button) push the paperclip right in that hole to manually eject the tray.
Good luck
Jun 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
CD stuck in Dell Studio 15.
you have to insert a needle in the hole located near to the eject button...
Feb 19, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dvd-rw drive not working
Hi Elaine, Usually DVD recording issue can be related to the configuration or Hardware itself. please check if standard CD/DVD recording option is active you can see it by right click on CD/DVD drive and properties. Please check the box highlighted below
If it doesn't work you can contact to DELL hotline or alternately you can post the outcome on here
Good Luck
Feb 07, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
82 people viewed this question
Top Dell PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a Dell PC Desktop Expert? Answer questions, earn points and help others
