I have installed a converter box we have a rooftop antenna, now I cannot record, it does not seem to find channel 9.1, 12.1 etc only 9, 12 etc I went from antenna to converter to DVD MWR10D6 to TV. My tv remote has a source selection- video, computer etc and I have tried all these I just get static recorded. With the converter box in line I use the tv remote to change channels on my other tv with a converter box I have to use the converter box remote but that is an older set this flat tv is new.
Any help would be greatly appreciated, thanks
How many TV's and converter boxes do you have? Is your new Flat TV hooked up to the converter box? If you have a new TV you might be able to do this without the converter box. Does your Flat TV have a "Video Out?"
If you have the converter connected to the recorder by composite or s-video(line inputs), you will need to specify which jacks from within the setup menu of the recorder. There are 2 sets of line inputs into the recorder, so you have to select the right ones. They are called L-1 and L-2. The L-1 jacks are in the rear and the L-2 jacks are in the front. The channel selection should also be on L-1 or L-2. If you are using the RF input(fat cable) to the recorder, you should have the recorder on the channel number that matches the output of the converter (channel 3 or 4). The converter RF output is selected by a switch in back of the converter or by the setup menu of the converter.
Menu path for setting L-1 or L-2 inputs: Setup > General Setting > Video > Video Input > L-1 or L-2 > Video In or S-Video In
Was this helpful?
Yes
No
Popular Solutions for Philips Magnavox MWR10D6 DVD
Our local power was off for 12 hours, when it came back on, the dvr will not turn on, although it...
(More)
Our local power was off for 12 hours, when it came back on, the dvr will not turn on, although it was on a surge protector, as was the TV and satellite box, which are working. Is it dead? Anita
