Question about Nu Mark Numark CD-Mix-2 Dual CD Player/Mixer Combo System
Moodey newmark cd mix 2
Hi, my newmark cd mix 2 left deck crackles upon start-up and then crackling dies down after about an hour or so of use,. Right deck now and then skips the last minuet {approx} of track but problem dose not persist when same cd is played in
left hand deck immediately after, I have located replacement cd players for this unit ,are they hard to replace?& do you think that this will cure the problems
regards G zod
  • rodgebrown Feb 18, 2009
    just bought one myself and I have exactly the same crackling problem with channel 1. it takes an hour to fade away. Very frustrating. Anybody any ideas?
Just wanted to tell you i have the same problem with my right deck! after about 2-3 hours of usage the right deck will start to skip while playing a cd...almost sounds like im fast forwarding then itll just stop playing, but only on the right deck! Ive noticed that it happens when the unit gets hot whether by usage or sunlight. Now as for youre issue about the crackling, i have two staements one is the cd youre playing scratched? ive had cds that have had minor path scratches that follow around the cd not straight across scratches..while playing this sounds like static or crackle then fades away! I would recommend playing the cd in a entirely different unit to see if this is the prob...if you know this is not the issue i would say that its a loose connection to a capicator or that a capacitor is on the way out...this happens when the capacitor is cold and doesnt let proper flow to go thru but as the capacitor heats up it it may heat the connection making a better contact.....just out of curiousity do you have the right rated fuse in the holder.. sometimes just having a fuse off by a couple of volts or milliamps can cause the same effect
Posted on Aug 20, 2009
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
I have a JVC KD-95 Cassette Deck. My left speaker Comes and goes lots of crackling. When I turn off the deck it crackles loudly then fades. my speakers work fine when using cd, radio etc.
Probably it's the playing head; must be damaged or worned out.. Accept fact; cassette players are outdated. make a listing of your favorite music and stat finding them on line.
By the way, even youtube rips are better quallity then thos cassette recors.
Aug 23, 2011 | JVC TD-W118 Single Cassette Deck
Got a crackling sound then it stopped playing.now every time i load a cd i get no disc.
technics wont play cd-r or any copy cd's thats why you get no disc but if this is the case with all cd's then it sounds like you need a new laser unit, the crackling sound is your laser breaking up, there easy to come by on ebay plenty for sale worldwide.
Feb 18, 2011 | Technics RS-TR272 Single Cassette Deck
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
Crackling / Popping sound in my PC's audio output
Your soundcard is going bad. The easiest way to fix is to replace with a new soundcard. Depending on what features you want the price could be anywhere from $35 to about $140. Hope this helps.
Aug 09, 2009 | Creative Labs Sound Blaster Audigy 2 ZS...
Whining and crackling noise
it might be or there could even be a loose wire in there somewhere. did you install everything yourself?
Apr 14, 2009 | Car Audio & Video
Numark CD mix 2
Hi aondj
I would remove the back panel, and get access to the soldering of the connectors that are giving you trouble. resolder them, and see how you go. Get back to me here if this does not cure it and we shall get into it further
regards
Graeme
Apr 12, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nu Mark Numark CD-Mix-2 Dual CD Player/Mixer Combo System Logo
226 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
