All "Youview" channels are working normally. I have tried reset on the Menu button with the same result Our grandson whose hobby is fiddling with the remote controls has just visited and I suspect that he is responsible for the fault
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
SOURCE: Panasonic Plasma no sound, can't change channel
Yes the control board would definitely be the offender here. But a word of caution. Oftenj when this board goes 2 other boards are also compromised and not always obvious at the time people think they can just swap the board out.
It went for a reason, not just old age. So it is better and cheaper in the long run to get a professional to check it out.
Also from a safety aspect, this is the High Tension area of the TV. Also be aware that radiation of the X type is in abundance at the rear of the tube. The TV must be grounded when opening ( but my advice is dont!) Let the professional do it
SOURCE: will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
SOURCE: My Panasonic TH-42PX60U Plasma tv will not respond
need panasonic remote
Manufacturer
Panasonic
Part Number
EUR7737Z20
Description
REMOTE CONTROL
SOURCE: I bought a Panasonic 42
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
