Question about PC Desktops
I need help getting dvd+rw drive operating
How do i get the DVD+RW working on Compaq SR1830NX?
been unsucessful at setup.
owned computer since new & now need this feature.
    Problem Solver:
  • 8 Answers
Re: I need help getting dvd+rw drive operating
go to nearer computer sales and support centre purchase a DVD R/W and if u have CD drive dis connect power cable and data cable then remove screws from cd drive then remove it fromyour cpu cabinate in same place insert your DVD R/W fix all screws,data cable and power cable.then connect all the data/power in backside of cpu if you r removed before otherwise again check all the cables and power on your cpu/moniter.after booting sucessfully your computer insert your nero cd which is given with your DVD R/W,cd automatically open then setup it one by one by soing instructions.after setup complete your DVD R/W is ready to read write CD/DVD.
Posted on Nov 13, 2007
0 characters
3 Points
My dvd-rw stopped working. when I close door, I hear a noise, the light goes out. nothing happens. Device manager says the drive is working properly.
it may be that the dvd/rw media needs to be the proper type. look at old media you have used in the past and insure the new media is the same. the 2 different types are dvd +rw, dvd+r, dvd-rw, dvd-r. the plus or minus are the fifferences you should pay attention to , unles your device is +or - compatable.
Jan 19, 2011 | HP Compaq Presario SR1330NX (PP161AA) PC...
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
When in ''MY COMPUTER'' - CD Drive (E:) was droped into DVD-RW (D:
Try uninstalling the drivers in device manager, shut down, reboot and Windows should find both devices, it might ask for your windows disk to install drivers or search online to install them
Jul 27, 2009 | PC Desktops
Compaq V2000 - Service Tag V2220US Only recognizes the CD/DVD drive as "CD" Does not see it as a DVD Drive. Listed as: _NEC DVD+-RW ND-6500A in Device Manager.
Try updating your drivers from
If the issue is that it won't play DVD movies only then you probably need to install or re-install the DVD player software that should have come with your computer. If you don't have it anymore, simply download from HP.
Apr 24, 2009 | PC Desktops
By mistake I bought a dvd rw disc instead of dvd-rw disc and recorded a holiday video on my camcorder with it. I usually then upload the contents of the dvd onto my hard drive (Pioneer) and then download...
Try uploading to your PC then converting it to AVI this keeps quality of video. Then if you want to download to a disk use Nero to convert it to VOB (DVD format) and burn off. You can also use Nero to erase the disk. (Nero 7 or more recent preferably.) You must also be sure you PC DVD read write head can take the DVD +/- RW. CHeck compatability.
Aug 12, 2008 | PC Desktops
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Dvd burner dvd+rw and dvd r problem
Hey Bruce - In your first post you said DVD+RW works which would make sense. In your comment you said that DVD-RW works which would not make sense. You've got to be sure. I'll you what it is supposedly direct from HP/Compaq:
Your PC will " supposedly do the following":
CD, DVD, CD-R, CD-RW, DVD+R, DVD+RW. These as I said are straight from the horses mouth. You can check for yourself.
PLEASE RATE FIXED if I answerd your question or please don't rate at all. It only hurts our ratings. I've done what I can for you. Thanks Bruce. If you need more help just add a comment and Ill be happy to assist you further.
May 22, 2008 | PC Desktops
Compaq CD Drive
It appears that the CD drive has failed. My DVD drive did that and I ended up replacing it. They have become fairly inexpensive. You can replace your CD drive with a DVD/RW drive for about $30. I like to use to find cheap computer components. Just check back regularly and a DVD/RW drive should show up.
Dec 31, 2007 | Compaq Presario 5000 PC Desktop
PC Desktops Logo
107 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
