Mostly nokia chargers doesn't make problems...
just try the following..
1.connect ur mobile with a system (usb cable)...if it charges then replace your charger fault is in their,
2.if problum not solved then,power off mobile,romove the back flip and remove the bettry,check the phone,s connecting metel terminals,
if they r slightly bent,bend them slightly upward whith the help of a pin,check metal terminals of the battry if they r ok then good othervise replace bettry with new one.
3.check the bettry in another cell phone if it charges theno problum is in ur cell phone or power jack(socket)...
IF Charging Problem not Solved So then contect a qualified repair.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Hi, try taking out the battery and see what happens.
It may be that when the charge port was short circuited it may have damaged the PSU. Do you have another one to try or may be borrow one from a friend who has a similar Dell Laptop.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all. Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
