Hello tonyludlow1, I can speak from personal experience with 3 phase. I built a 220v 3phase converter to run my 3 phase commercial table saw. I do not believe you will have success running a 310v 3 phase coffee unit. It is likely that the heating elements are set for 310v, and if you run it on 220v domestic wiring your heating elements would not heat optimally. If it could be done, you would need to rewire the electrics in the coffee unit to 220v. Sorry to be a downer. Positive feedback appreciated. Kind regards, NormanZ :o)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
The milk heats up, but the wisk inside is not turning so the milk is not being frothed. How do you...
(More)
The milk heats up, but the wisk inside is not turning so the milk is not being frothed. How do you fix this?
Upper seal is not mating properly to re-fillable K-cup. Leaks less when seal is slid down slightly...
(More)
Upper seal is not mating properly to re-fillable K-cup. Leaks less when seal is slid down slightly on water supply piercing needle. Not sure where to get replacement upper water supply seal.
