Question about Creative Labs Zen Touch MP3 Player
Headphone jack left side wont work with any set
  • 17 more comments
  • megkay Nov 21, 2007
    I've got the same problem. At first I thought it was my headphones, but I'm reading more and more about people having problems with the left headphone. My only theory would be that the shaping of the headphone jack is messed up, which would be a manufacturing error. It seems pretty common, too.
    Still, I'd appreciate any suggestions or solutions.
  • Anonymous Dec 15, 2007
    We've had the same problem.
  • ejb2 Feb 03, 2008
    Same problem. This also happened after a time on an RCA Lyra mp3 player I had. Evidently the connections inside the earphone jack are cheaply made/not made to last. Why it is always the left channel that goes out I am not sure. Has anyone had this repaired?
  • puhlio Mar 19, 2008
    Same problem, first the left headphone went out and now the right side is cutting out. Is there a repair facility that does repair work on these?
  • kiwilele Mar 26, 2008
    I have the same problem. Left earphone jack and then the right one. I'd like to get it fixed but don't know where to go.
  • fixerguy22 Apr 22, 2008
    Headset jeck only working on one side or cuts in and out.
    The solution is to take apart the shuffle per instructions found on YouTube. On either side of the headset jack you'll see a small metal tab that connects to the printed circuit brd. What happens is this connection breaks. You can see this if you put the headset plug in and wiggle it, the small metal tab will lift off the board. I stuck the end of an unfolded paper clip on the metal tab and then heated the paper clip about 1/4 inch up from the end with a soldering iron. This reflowed the soldier and fixed the problem. You need to do this fix on both sides.
  • PVC101 Jun 01, 2008
    I took mine in to a local computer repair shop. They re soldered the joints, but after finding that it didn't fix it, he suggested the contacts were badly tarnished and had lost their springiness. The x20 headphone jack is a special one though, it also acts as a switch for the player's built-in speakers. He suggested I find a new jack for it, but I don't know where to find one. Help!
  • Anonymous Jun 08, 2008
    it stopped working about 4 months after buying my sansa e250
    I thought that I`m only one, but it`s big problrm (and annoying!!)
  • Sir_Nigel014 Jul 05, 2008
    It's claiming my left earphones. For months I had the problem of it wouldn't play in the left earphone unless you adjusted it, but now, it's claiming my left earphones (i.e. the set of headphones will not play on left side when I use it into other devices like my laptop, other MP3s, etc.)
  • awesome_em Jul 11, 2008
    i have the same probleum too and its so annoying please o please will someone tell me a repair shop to go to or something like that...thank you so much
  • susiel Jul 11, 2008
    i have the same problem....if you mov the headphone around in the jack, it will work in the left headphone only if you hold it....however the sound quality greatly changes when you move it..
  • Anonymous Aug 04, 2008
    My left side headphone isn't working either, unless of course, it's partially plugged in. I just discovered the other day that this problem is my player and not the headphones when I was at the gym and randomly plugged my phones into the dock to watch tv... what a surprise when both sides worked! I've bought several pairs of headphones too... seems like this problem is a defect (since SO many people are having it).
  • dudemanh Sep 05, 2008
    on mine the headphone jack does not work at all now... and i have no idea what the problem is so if i can get any help that would be great...
  • Anonymous Sep 13, 2008
    I have the same problem! I have to hold it the whole time to hear from both sides.
  • Droid64down Oct 11, 2008
    When ever i put in my headphone only the left side works i have opened it up and tried to find what was wrong please Help!!!
  • grebnetro Dec 21, 2008
    I'm having the same problem. The right seems to be a little quieter, and the left only works if you press the jack. I've tried heavy duty tape to keep it in there, but that doesn't work.
  • ddtrumpet Dec 24, 2008
    Same here. Headphones work fine with other players and other phones that work elsewhere don't work in this player's left channel. Seems the player's not sending any signal to the left channel side of the jack.
  • Anonymous Jan 31, 2009
    I went into my local Apple Store, and they said clean it with a 0.5mm Inter-dental brush, I did so, to no avail!, I don't want to go back, (my iPod Touch is Jailbroken) and they wont fix it, I can either restore and get it fixed, or just put up with it, what should I do?! xD
  • Anonymous Feb 06, 2009
    I have the same problem (left side of heaphones wont emit noise unless the jack is pushed) I gave it to a guy at a computer repair place, but they said i need to find the replacement part online!
I have the same problem - I have to hold the plug the whole time for sound to come from both ears.
Posted on Sep 13, 2008
  • 3 Answers
I found a like 2 help. i just cant figure out how to remove the ram card. this is for sansa e200 only. i dont know about the e200r.
bacically: open it up to just the motherboard if the head fone jack comes out, then you have to (some how) open up the ram card and solder it back in
once again, if some one could help me with the ram card it would help
Posted on Aug 03, 2008
I've had the same problem. Under UK law (Trading Standards and Consumer Rights Act 1982), a product must perform its intended purpose for a reasonable period (generally recognised as six years). Don't accept the 'out-of-warranty' have the right to get this fixed.
Posted on Jan 19, 2008
Note this solution is for the Sansa e200.
OK, same headphone jack problem here and a bunch of people have the same problem. It got so annoying that I decided to risk the consequences and rip this baby apart. Sure enough one of the jack legs had a cold solder joint (the solder had not completely reflowed over the pin). I could press on the edge and see the pin lift away from the PCB pad. Looks like the others were touched up by hand because the pins were completely covered but the pin for the left side had been left as is. It is also the hardest to get at (because the SD cage is right next to it) so I'm wondering if they got sloppy and have a major quality problem with these. It's an easy problem to fix if you have a fine point soldering iron (big IF). A few tips: 1) Once you have the 4 inner and 4 outer screws off you have to carefully pry off the front cover, so be careful here 2) you then have to gently get the PCB out by carefully taking out the connector side first 3) there may be a riser card you have to take off to access the culprit jack pin, it is attached with some doubled sided sticky foam. Hope this helps.
Posted on Nov 18, 2007
OK, here the deal. I got ********** cause my warrenty was done so heres what i did to fix the problem.
What you need:
Paper (Little bit)
***** driver (to open sansa)
Open up the sansa all the way until only the motherboard remains. *the one with the headphone jack)
At the back of the motherboard is the headphone jack, i figured out that if u push this guy down, both headphones work. So all i did was stick a lil bit of paper on that jack itself so when i put everything back together, the headphone jack would stay in place.
need help, reply
Posted on Mar 12, 2008
Only one side of headphone jack works
are you using the correct size jack? they do come in different sizes
Jul 18, 2015 | Audio Players & Recorders
IRiver E100 headphone jack
The connector is defective - probably just wear and tear
Aug 15, 2017 | iRiver E100 Digital Media Player
Ive a problem with the volume of the headphones, the right one works fine but there is no sound from the left side....ive tested the headphones on other electronic equipment and the headphones work the...
Hi,,in most cases what causes one side of the headphone to work is because, the wire that is connected to speaker inside the headphone might have cut and it's not contacting properly.
What you will need to do is to open up the head phone (left),and check if the wire inside has not cut, If it has removed ,then you will need to put it back with soldering iron and a lead...
But if the wire inside has not removed and they are intact, then you will have to replace the left speaker .
Hope that helps...
Thanks for using fixya...
Nov 08, 2010 | Audio Players & Recorders
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Jul 10, 2010 | Element ELC-HS321 32 in. LCD TV
No volume on tv showing a set of headphones when u turn volume up or down
Your headphone jack, located on the left side of the TV, may need cleaned out. Try inserting and removing a 1/8th inch headset into the jack about 10 times to clear any dust from the connection. If this works, put a piece of tape over the jack so this does not reoccur.
Mar 14, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I am having the same problem with a twist, sound works from the fm and headphone but only from the right side no left audio. I have the 760 and it only has one speaker and my guess it that it gets its feed...
If you use the headphone jack a lot and your missing the audio from the speaker and one channel from the headphone jack, then it's possible that some of the headphone jack connections have broken off of the PC board. The audio goes to the speaker through the headphone jack.
Please see this link for more info and read the section about the headphone jack.
- Jim
Dec 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
Left side quit working, not earbuds, i tried other sets
I had the same problem. the stereo mini jack connection to the circuit board of the mp3 player is broken or loose. I jiggled the jack around and the sound came back into both ears but that only worked for a little while and is annoying. Basically, unless you can re-solder the mini jack to the circuit board, or get someone to do it for you, your player is now just a flash drive.
Aug 08, 2009 | Mach Speed TRIO Onyx MP3 Player
2 sets of headphones will play only on left earphone.
Dirt inside of the headphone jack can be the culprit. If you have canned air, you can blow it out, or twist the headphone connector inside the jack to clean the contacts.
Dec 20, 2008 | MyMusix PD-6070 MP3 Player
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
Nov 25, 2008 | Denon AVR588 Receiver
Replace the player - there is no repair for this
Jul 02, 2007 | iLO (2 GB) MP3 Player
Creative Labs Zen Touch MP3 Player Logo
682 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
