Question about Dell 922 All-In-One InkJet Printer
Paper feed Printer will print but has lots of trouble feeding the paper into it and often claims out of paper but fully loaded. Struggles pulling it down into the printer.
  • 3 more comments
  • rickwet Nov 20, 2007
    rick
  • Anonymous Dec 02, 2007
    Same problem! Always crooked at best. Tried to adjust the pull wheel and now it doesnt pull at all. Should I just buy a new one?
  • Anonymous Dec 10, 2007
    I tryed cleaning it, but it simply doesn't work
  • Anonymous Dec 16, 2007
    Printer loads with one side (left as you are facing the printer) lower than the other, feeds in a 'crooked' alignment and prints askew. No lint problem, but this seemed to start shortly after replacing the ink cartridges (with Dell ones).
  • Anonymous Dec 18, 2007
    I have to push the paper down for it to catch to print.
I decided just to beat the hell out of mine with a hammer. I definitely felt better afterwards.
Posted on Dec 23, 2007
The feed rollers are probably dirty from paper lint. The feed roller on the 922 is on the right side as you face the front of the printer. I use a damp sponge to clean it. Good luck.
Posted on Dec 03, 2007
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Wont print no paper feed but the sound come out of the printer as if it was woking
If the paper isnt being pulled in the chances are that you have a foreign object in the paper path. First of all turn the printer off & disconnect all cables. Turn the printer upside down and give a good shake, with luck the blockage should fall out. If not then you need to be a bit brave, make sure the print carriage is parked fully to the right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Apr 15, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Paper feed not working
remove the paper from the machine and look where it feeds in. There should be some rubber rollers, try cleaning them with a rag and some rubbing alcohol. If this doesn't work let me know. Also fan the paper before loading it. John
Jul 07, 2007 | Cannon i70 Printer
Dell 922 All-In-One InkJet Printer Logo
128 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
