Question about Amana ABB2227DE Bottom Freezer Refrigerator
Stabilinzing My Amana bottom freezer is on wheels and I cannot figure out how to bring the so called "legs" down to stabilize it. There are only 3/8 inch hex screws on the left side and I tried turning them all but nothing changed. Everytime I open the door it rolls out toward me. How do I fix this?
Simply unscrew the "legs" to lower them. I've found the best thing to use is small slip joint pliers. Just grasp the rubber feet and unscrew until the legs are carrying the weight of the fridge.
Posted on May 29, 2008
How to level a new fridge
On the bottom front you should have wheels they may be adjustable depending on the model. Otherwise you will see some octogon looking legs that can be adjusted. You may need a wrench to raise it. Right will bring the legs up and left will bring the legs down.
Sep 04, 2014 | Panasonic NR-BY601VSPH
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
I downloaded the manual for this unit and it says to adjust the front leveling wheels to bring it to level. I removed the grill and looked for the adjustment screw...there is none. shimming is not an...
Front wheels should screw in and out for adjustment purposes!!!!!!!!!!!! And with that degree of tilt you might just have to resort to shimming so be ready.
Aug 27, 2017 | Amana ATB1932MR Top Freezer Refrigerator
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
How do level out the upper doors on the Amana bottom freezer French Door refrigerator?
The ref is not usually at fault your floor is uneven.
Shim either the left or right rear wheel 1/4' at a time.
This will take the twist out of the box and Lvl. the doors.
Use hard board avail at Home depot.
2x4' sheet and have them cut it into 3 8" strips
then have hem cut one into 4 12' rectangles.
Use the long pices to roll your ref. out onto so you protect your floor.
Use the small ones to shim the rear wheel.
Jan 15, 2010 | Amana AFD2535FE Bottom Freezer French Door...
How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
May 02, 2009 | Amana ATB2132ARQ 33" Top Freezer...
My refrigerator gurgles when the bottom freezer door is closed?
Air is stabilizing between the fridge and freezer.
Do not worry.
Mar 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Have Amana refrig with bottom mounted freezer Model ARB2217CW. Noticed the last day or so it makes a buzzing noise--almost like an electric shaver then it shuts off with a click. Today items in freezer...
See the post by lola77 with the same complaint. We have an Amana top/bottom freezer and are having the same problem and we've only had it 4 1/2 years. First service call available that the 1-800 number gave me was 3 days from now, which is ridiculous.
Aug 27, 2008 | Amana Refrigerators
Amana ABB2227DE Bottom Freezer Refrigerator Logo
111 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
