Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
HOW TO USE ABOVE HARD DRIVE
DO I HAVE TO HAVE ADDITIONAL POWER TO USE THE ABOVE HARD DRIVE?
  • 34 Answers
Non normally on usb hard drives but to confirm this, is there a power connection on the drive?
Posted on Nov 12, 2007
Where does the p8 and p9 plugs go
They are just 2 of the 5 '4-pin' molex power connectors.
They are used to power the old PATA-style (and some SATA,) Hard drives and CD/DVD Optical Drives. Many additional Cooling Fans will also have 2 power connections, one for the 3-pin motherboard and one 4-pin Molex, either one may be used to power the fan.
If you have already connected your Hard drive and Optical drive and do not have any additional fans or Secondary Hard drives or Optical drives.....they should be 'tied-off' with a twisty and tucked away somewhere so as not to interfere with airflow throughout the case.
May 29, 2014 | Dell Dimension 2400 PC Desktop
Hard drive not being recognised by compaq presario SR1975AN on warm boot
The hard disk may be running too hot.
The desktop case inside temperature maybe too hot. Check the power supply fan/CPU fan are operating correctly. You may need additional cooling in the desktop case an additional fan near the hard disk.
Mar 23, 2012 | Samsung SA07HD103SJ Samsung HD103SJ 1 TB...
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
When ever i plug in my hard drive to laptop the light on my passport goes on but its not letting me get to my files...
Tribesman,
On occasion the power supplied to these types of external harddrives is not enough to satisfy the power needs of the device. Sometimes additional power is needed - an easy way to test this is to try plugging the drive into a usb port on the back of a desktop and see if you have the same problem.
Additional power can be provided via a special type of cable that allows you to draw additional power from a second usb port on the computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200736&cm_re=external_hard_drive_usb_cable-_-12-200-736-_-Product
Please let me know if you have any additional questions.
Thank you.
Mar 21, 2011 | Western Digital 1TB My Passport Essential...
I bought a 1T 7200 as a second drive. I was sold a sata cable only do i need a power cable also?
All SATA drives need a signal cable and a power cable, but usually these cables already exist inside your computer waiting for you to use provided that your motherboard allows for an additional drive.
Mar 18, 2011 | Seagate Barracuda 7200.10 ST380815AS 80 GB...
My drive want power up when plugged into my laptop.
The 1TB My Book Drive usually requires an additional external power supply and does NOT power up from the USB cable alone. Only the small 2.5" drives requires no addition power supply.
Feb 02, 2011 | Western Digital My Book Essential 1TB...
When I hook-up to my laptop ( Lenvono X200. The drive spins but does not connect. The blue LED light comes on for about few seconds, then goes off.
You *may* have a problem with this particular drive and laptop combination due to the amount of power available at the USB connector of the laptop and the power requirements of the drive. Sometimes, there simply isn't enough power at the USB port to power the drive. This can be a result of low battery power, having other devices connected (at the same time) to other USB ports and, in the case of earlier laptops - a lower designed USB electrical rating (the newer laptops have enough power to power these drives now). The early USB ports basically were for connecting mice, cameras, and small thumb drives.
You can check yourself by seeing the drive works on another computer. If it does, it is likely this power problem described above. You can get around the limited power problem by purchasing a AC POWERED USB hub. A powered USB hub will need to be plugged into house current and will provide the power needed by the drive. This frees the laptop power supply from trying (and failing) to supply the power needed by the drive. Of course, this limits the portability of the whole set up - needing a source of AC power whenever you want to use the drive can be a hassle. Smaller capacity drives usually have lower power requirements, and may be a better option if additional portable, hard drive space is needed.
I hope this helps!
Mar 19, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a 1 Terabyte Iomega hard drive model # MDHD10T-UT Serial # JPA80302B8 I just stopped showing up on my desktop and I can not mount it. I have tried Disk Warrior, Data Rescue II and FileSalvage....
The Drive is not damaged - the power supply has failed it has happened to me 3 times.
Currently Im trying to get additional power supplies from Iomega. If I get additional info I will updated
Jul 30, 2009 | Computers & Internet
Video card
the requirements are
FOR WINDOWS XP
  • Windows XP (Service Pack 2)
  • 2.0 GHz P4 processor or equivalent
  • 1 GB RAM
  • At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
  • 128 MB Video Card with support for Pixel Shader 2.0
FOR WINDOWS VISTA
  • Windows Vista (Service Pack 1)
  • 2.4 GHz P4 processor or equivalent
  • 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
  • Intel Integrated Chipset, GMA X3000 or above.
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
So what does your computer have?
Jun 02, 2009 | Microsoft Windows XP Home Edition
Computer isn't recognizing hard drive
Unable to see full amount of hard drive. Additional information and help with why the computer may not recognize the hard drive
Good Luck, Click on the link above follow instructions, Please dont for get to Vote, Thank You.
Dec 16, 2007 | HP Pavilion dv9000z Notebook
Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
98 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
