Hello;
My name is Peter. I am a retired field service refrigeration technician.
Oscar is correct. However, if you have a double door this is not possible.
If you have a single door, you most hold the door in position when you tighten the top flange.
You may want to leave the top flange loose and adjust the bottom front leveling screws until the door moves into a good seal position.
why would someone want to REVERSE a double door ??
Hello Oscar; I have been on service calls where the customer had purchased a unit slightly larger than the original unit. Here, the unit was press fit into the existing space. Opening the door, the thickness of the door had interference with the kitchen wall and would not open all of the way.
Most refrigerators and freezers have the option of door reversal......look on the opposite side of the door and there should be screw holes under plastic plugs....which will enable you to swap the hinge to the other side.Here are a few pics for reference.
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
