SOURCE: samsung le26r74bd won't retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
This is really just a suggestion:
Have you tried with the remote to direct enter (number buttons) a channel to see if it goes there and has signal?
If so and it does you can direct enter each channel and save them by using that feature in the set---that way you will at least know if signal is reaching the set.
Also if a DVD etc. works connected to a rear input you should be able to use a output of the same type from a box (cable or sat) to hook up that way and not have to bother with the set's own cable/coax connections.
I do not of course know what is used for signal or how hooked up but this suggestion should tell you if a tuner problem in the set or not.
