Edu-Science (10166) Telescope Logo
N
None ofyour business Posted on Feb 19, 2015
What is a dependent variable - Edu-Science (10166) Telescope
2answers
What is an dependent variable
All values that arise as influenced by changes in the values of other variable. Or, Dependent Variable is the observed factor.
If we have a Linear Function as
Y = mX + C
so,
Y should be Dependent Variable,
X as Independent Variable,
m as Coefficient and
C as Constant.
2answers
What is an independent variable?
An independent variable is not directly or indirectly related to another
What does responding variable mean?
The responding variable is another name for the dependent variable.
On a graph, the x variable is the independent variable and the y variable is the dependent/responding variable.
I remember the difference between the two in that the dependent variable depends on the independent variable. For example, for teenagers, in height versus age, the age would be the independent variable and the dependent variable would be the height. We would expect as teenagers get older, they are taller.
Let me know if you have any questions.
Good luck.
Paul
  1. Dependent Variable: A dependent variable is what you measure in the experiment and what is affected during the experiment. The dependent variable responds to the independent variable. It is called dependentbecause it "depends" on the independent variable.
What's a dependent variable
The dependent variable is the one that "depends" on the independent variable. If we were looking at the size of houses in square feet to the cost of houses, the size of houses would be the independent variable and the cost of houses would be the dependent variable. In an X-Y plane, x is the independent and y is the dependent.
Good luck.
Paul
1helpful
I am doing an experiment. i am using water. I am trying desolve salt,grits and pepper in water. would water be my independent variable and the salt, grits and pepper be my dependent variables?
Hey there,
Dependent variables are the output of certain actions or variations in the independent variables. In this case, the dependent variable would be the sludge you create. The water would be a constant medium to the independent variables grits,salt, and pepper
Oct 04, 2013 • Finance
When conducting an experiment, a researcher usually has a dependent and independent variable. The independent variable is the variable that can be changed or manipulated (think of it as a cause). The dependent variable is the variable that depends on the independent variable (think effect).
For example, if you wanted to test whether or not taking Advil affects the length of a headache:
  • Taking Advil (or not) is what you can manipulate. It is the independent variable.
  • Headache duration is the dependent variable. The results depend on whether or not Advil was taken.
Sep 16, 2013 • Finance
1helpful
I have a project and i don't know what independent or dependent means
For example, if you wanted to test whether practice improves an athlete's performance (lets say number of touchdowns):
  • Practicing (or not) is what you can manipulate. It is the independent variable.
  • Number of touchdowns is the dependent variable. The results depend on whether or not the athlete practiced.
Sep 07, 2013 • Finance
6helpful
2answers
Examples of independent and dependent variable
hi.
for a full definition, try wikipedia.
an independent variable can be freely changed.
a dependent variable will BE changed as the independent variable is changed
basically there are 2 main examples. mathematical, and experimental.
with experiments,(science, chemistry etc.) one example would be changing the amount of fertilizer fed to a plant to see how it affects growth. there are 2 variables here. amount of fertilizer used and growth of the plant.
the amount of the fertilizer can be freely changed. (independent variable)
the amount of growth DEPENDS on the amount of fertilizer (dependent variable)
with maths, you can use something like 2x+5=y.
x can freely changed. it is the independent variable. y will change depending on the value of x.
hope this helps
Jul 04, 2011 • Cycling
Top Edu-Science Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
