Why hp printer takes paper but stops in the middle
I would start here by cleaning the feed rollers but there could be several causes to this. It could be the fuser film is slipping and not getting the paper out in time thus throwing a false paper jam message. It could be the fuser isn't turning at all and not allowing the paper to enter. Normally if the paper is making it out of the tray then it isn't the feed roller but that is always the cheapest place to start. You can clean the roller(s) with an alcohol wipe or rag with alcohol on it.
Does the paper make it past the toner cartridge? I have seen toner cartridges lock up and cause this type of problem as well. If the paper isn't making it past the toner I would try replacing the cartridge (even if its with an old one just to test the paper path).
