Were does the white wire connect to behind the sreen
SOURCE: I have a toshiba c655d
Hi boris jurado...
Sounds like your LCD is faulty, if it works with another external monitor, then that is normally the problem.
You will need to change your LCD to correct this problem.
Please take time to rate me
SOURCE: I have locked my self out of my Toshiba satellite
Try the following: 1.Press CTRL+ALT+DELETE to unlock the computer. 2.Type the logon information for the last logged on user, and
then click OK. 3.When the Unlock Computer dialog box
disappears, press CTRL+ALT+DELETE and log on normally. Hope it works : ) and if it doesn't please try to clarify what exactly is happening-like how is it locked, so i can look into it more and try to resolve the issue. But for now, lets hope it does : )
SOURCE: toshiba satellite C655D-S5300 bios reset
To reset toshiba password, you can use Smartkey Product Key Recovery to help you, and you can see more detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
SOURCE: toshiba satellite c655d screen won't come on
Try holding the power button in when your booting for 5 seconds, not long enough for it to shutdown again
1. push it to power up leave your finger on it for 5 seconds
Let me know
SOURCE: OK can someone help. I have a Toshiba Satellite
Go to http://support.toshiba.com/support/modelHome?freeText=3133792 and download the Atheros Wireless LAN driver
Testimonial: "ok how do I know its the Atheros and not Realtek?"
Try the following:
then click OK.
Hope it works : )
the end in the LCD cover is attached to an antenna.The other end connects to your wireless card.
