Question about Toshiba TDP-T30U Multimedia Projector
Toshiba projector TDP-T30
I have above projector and it recently started to display black vertical lines on top of an image that seems to be broken and colors are boxy. I thought it might be the blub, so I replaced it and reset the system 3 times. At a loss. Please give my some guidance.
I have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Posted on Feb 09, 2010
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
Thin black lines: projector TDP-ET20
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Sep 26, 2009 | Toshiba TDP-ET20 DLP Projector
Is toshiba TDP-S8 good projector because I bought it today for $ 300.00 used. Thank you
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on ebay.com for reasonable prices.
Jul 01, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
We have a Toshiba multimedia projector. Model #TDP-S8. Use app. 3 hours weekly for church services. Three weeks ago, started with changing color. White looked lavendar/gray, etc. Now it consistently has a...
it needs a good service .all that needs to be done is open the top cover, the main board , clean all the dust possible.there is a glass dlp , clean it with a soft cloth ( like the one used to clean specks).on refiiting the main board make sure to firmly press the 100 pin black connector on the dlp board engine.this is the cause of the vertical flashy line
once repacked start the unit.it should work fine!!!!
Jan 10, 2009 | Office Equipment & Supplies
Large white vertical bar thru picture during projection
Two reset attempts to factory settings seems to have been the fix.
Feb 01, 2008 | Toshiba TDP-S8 Multimedia Projector
Two or more black bands appear
Try resetting all parameters to factory settings. Do it once and then set your personal settings. Then, reset to factory defaults again.
Jan 23, 2008 | Toshiba TDP-S8 Multimedia Projector
Black bar on bottom of image when i turn on projector
Projector Doctor in San Diego can do PS and board level repairs on this projector.
Feb 20, 2007 | Toshiba TDP P4 Multimedia Projector
Toshiba TDP-T30U Multimedia Projector Logo
214 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
