Question about Akai PDP4290 42 in. EDTV-Ready Plasma Television
50" Akai Plasma Power Problems
I was watching my tv and it just went blank. I got up to turn it off and the control does nothing. The power lights are still on and the screen switches between a black and light grey screen and the tv will not turn off unless it is unplugged. As soon as you plug it back in it comes on and will not go off. Any help?
Re: 50" Akai Plasma Power Problems - Akai PDP4290 42 in. EDTV-Ready Plasma Television Flat Panel Televisions
Tha same problem
Posted on Mar 14, 2008
0 characters
3 Points
No picture
It's obvious that the power supply failed. The most common parts in a power supply are a thermistor or a voltage rectifier, possibly even a voltage regulator. diodes or resistors can act as fuses too. A ringing sound can come from a fixed coil that isn't kept still with enough epoxy. Hope this helps.
Nov 26, 2013 | LG 50PS60 50 in. Plasma HDTV
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Feb 24, 2010 | Samsung 50 in. Plasma TV
I have a Hitachi P50T501 plasma tv. The screen went blank while watching it. We have been unable to watch tv or dvds. The power light is blue.
Tries unplug,replug about 1 hour later,if doesn't work,than Ur main video backlight board it dead,must replaced.
Nov 20, 2009 | Hitachi P50T501 50 in. Plasma HDTV
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
Trys to power up makes Buzz, then nothing but light stays green.
those vizio plasma have a lot of problems, its still most likely the Ysus board, but it will have to be tested to know for sure. If you bought it at coctco you are in luck, if bought a couple of years ago they will give you a full refund. you can try replacing it yourself by checking or ebay
Jan 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Big POP no sound no picture
if you could see light orange or green is has power is probably teh Y and Z board
Aug 22, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4290 42 in. EDTV-Ready Plasma Television Logo
191 people viewed this question
Top Akai Flat Panel Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Flat Panel Television Expert? Answer questions, earn points and help others
