Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Filter we are hooking up model FRS26H5AS Side by Side. The water won't go through the filter. My husband got the filter out, any suggestions?
  • 44 Answers
Hello, what is your water pressure at the house? Is it above 30psi? If so you might try replacing the filter maybe you got a defective one? I know this may sound silly but was the wrapper removed from the filter? Good Luck! Dr. Know
Posted on Dec 23, 2007
Good Afternoon Joe, thank you for your post!
I understand the water dispenser of your Frigidaire refrigerator is not working. First, I suggest checking that the water valve is completely open (typically located on the back of your refrigerator). Second, when was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. Also keep in mind that a clogged water filter or a blocked supply water valve may also lead to no water to the dispenser. If that is not the issue, than your refrigerator could possibly have a faulty valve, dispenser control board and/or failed water valve diode. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Jan 11, 2014 | Frigidaire FRS26H5AS Side by Side...
No water after replacing filter
Did you turn the water supply off when you changed the filter and then purge the water for a total of 3 minutes?
Sep 22, 2012 | Frigidaire FRS26H5AS Side by Side...
I can`t find the water filter
Dont know the model right off but the water filter is usually in the top back on inside of fridge usually where the dials for temperture are located
Mar 19, 2011 | Frigidaire FRS26H5AS Side by Side...
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!!
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
After changing water filter,ice maker no longer makes ice.
Is the filter in correctly? no offense. Give it time to purge any air and operate by its timer and cycle. Changing the filter has no connection with ice making , as long as it gets water.
Nov 17, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker not making ice
there is a separate solenoid that controls the icemaker its on the back of the fridge on the bottom.
it may have stopped working or the filter is clogged.
its a simple fix but it takes some know how to do so.
Mar 27, 2009 | Frigidaire FRS26H5AS Side by Side...
My dishwasher won't drain
It is possible that it ran thru the entire cycle but was unable to drain teh waste water ( usually the result of a clogged filter screen in the bottom of your dishwasher).. I suggest you either hand bail the water out and look for the drain filter screen or check where the drain hose is hooked up under your sink and possibly into the side of a garbage disposal..That could be clogged up too... Hope that helps...
Aug 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
