1995 Plymouth Voyager Logo
A
Anonymous Posted on Feb 19, 2015
Top radiator hose gets hot but not the bottom, also only one heater hose gets hot.
3.0 V6 water pump recently changed
Richard Faber
Level 3:
  • Plymouth Master 1,326 Answers
  • Posted on May 06, 2015
Richard Faber
Plymouth Master
Level 3:
Answers
1326
Questions
Helped
355728
Points
4152
No water circulation blockage in radiator, check for temp different in top and bottom of radiator
danoyachtcap
Level 3:
Top Expert:
  • Plymouth Master 2,907 Answers
  • Posted on May 01, 2015
danoyachtcap
Plymouth Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1274831
Points
52081
F your engine is overheating, Try this procedure:
  • Dirt and debris can get lodged in the radiator air flow paths. This can block the radiator and cause your engine to overheat and damage the engine.
  • The thermostat can be stuck close. If you feel the upper hose very hot and the lower hose cooler than normal, it may be a stuck thermostat.
  • Make sure the radiator and the overflow bottle are filled to the proper levels.
  • Bleed air from the coolant system:This is best done by running the engine with the radiator cap off until you see when the air bubbles stop coming up.
  • Check the radiator fans: The easiest way is to turn on the cars air conditioner and turn up the A/C fans. Both radiator fans should come on when the A/C starts
  • Make a pressure test by using a pressure testing tool (available at most auto parts stores). Use the pressure shown on your radiator cap. Most cars are 16 PSI or less, so don't exceed that pressure. Replace the radiator cap if it doesn't hold the pressure.
Dan Suddeth
Level 2:
Sergeant:
  • Expert 287 Answers
  • Posted on Feb 19, 2015
Dan Suddeth
Expert
Level 2:
Sergeant:
Answers
287
Questions
0
Helped
63856
Points
629
Just because the water pump was just replaced don't mean it wont fail. Pull the thermostat out and put back together with out thermostat (for test purposes). Fill cooling system and run unit with radiator cap off. If water pump is good you will see water circulating and swirling where radiator cap would be.If it is good turn heat control for heater to off or cold position put radiator cap on and run vehicle about 1200 RPMs for a while.(note it will take a lot longer to get water hot with out thermostat in). Watch your temp gauge and when it comes up some feel the top and bottom hoses to see if there temperatures are close to each others if they are water is flowing thru the radiator.Bottom hose will be cooler than the top because the water cools off going thru the radiator.Now open the heater valve on the heater to hot it should blow warm air about what the bottom radiator hose is. Take the thermostat inside and put it in a pot on the stove with a thermometer and see if it opens at the temperature that is stamped on it. The above steps will show you where you have a problem or problems at. hope this helps you out.
ronald e sullivan
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 113 Answers
ronald e sullivan
Expert
Level 2:
New Friend:
Cheetah:
Answers
113
Questions
0
Helped
25095
Points
377
Ck. your antefreez make sure full dont work look for valve on heater hose make sure it opens if not open by hand see if hose get hot a trie
gregmk
Level 2:
Sergeant:
  • Expert 204 Answers
gregmk
Expert
Level 2:
Sergeant:
Answers
204
Questions
0
Helped
86365
Points
896
Sounds like the thermostat may not be opening.
1helpful
I have a 1991 Ford Ranger 2.9,and I am having a heat problem I did change the thermostat but no heat yet,this is what I found so far. I checked top radiator and its hot,the bottom hose on radiator is cold....
ok in the engine compartment look at the radiator with the engine cold NOT ON" squeeze the hose with your fingers and feel if hose is crunchy or brittle if is possible a block could have happen locations /points at the vacuum heater valve gate on the heater hoses or a clogged up lower heater hose get a water hose and back flush the heater's hoses normal travel of water is from bottom to top so put the water hose to the tophose and flush backward and try to move the heater valve by finger and see if you get flow (mind you with hoses of the radiator DONT CRANK YOUR ENGINE)
1helpful
2answers
Lower radiator hose stays cold after running for hours
could be you fitted the thermostat in the wrong way around ,or the plastic impeller on the water pump with a steel drive shaft has failed they end up with the drive shaft spinning but the impeller is not turning ,go for the thermostat first though .
1helpful
1helpful
2002 dodge 1500 Changed radiator, thermostat, and hoses. No heat
Why was radiator replaced?Did it have heat before ? If it was plugged, the heater core may also be plugged. Try flushing it with a water hose in both directions. I dont know why the botton radiator hose would be cold, the radiator should be a uniform temp and the air coming through the radiator should be HOT, when the engine is at operating temp. What condition was the old coolant? if it was rusty, the water pump may have lower flow than normal.
1helpful
2answers
Radiator problems
it may be a little off, but the lower water hose seldom gets very hot,, as its this hose that suplyes the engine with ""cold water"" the hot water comes out the top hose,, drains down the rad and cools on the way down then enters the engine through the bottom hose """if your engine stayes running in the normal place on the gage,,,and not over heating""" why are you spending money for nothing???""
you wont get the bottom hose to run hot unless the engine is cooking
2answers
Overheats gets hot on the top of the motor but at bottom hose from thermastate it is cold changed radiater and put in two thermastates still gets hot help
1. In order to eliminate, remove the thermostat altogether, for now.
2. Make sure the heater bypass hose is working. You could route the hose going into the interior heater and bypass the heater also.
It should eliminate a lot!
Next, consider the water pump.
Hope this helps!
2helpful
2answers
Cooling system requires burp.
A large air pocket can sometimes be tricky to get rid of. The easiest way is to jack the front end up in the air with the wheels off the ground and support with jack stands, remove the radiator cap(make sure engine is cool) and allow to sit over night in this condition. The elevated front end will allow the air pocket to move to the most highest point and then escaping out the top of the radiator, after doing this procedure make sure to inspect coolant level in radiator and overflow reservoir and top off as needed.
Cooling system in my 1993 Ford Explorer over heats
change the water pump and check for a blockage in the waterjacket
Top Plymouth Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
