Question about DeLonghi AR1070 Retro 1500 Watts Toaster Oven with Convection Cooking
Oven temperature oven overheats
  • DeLonghi Master
  • 19,396 Answers
Test and eventually replace the temperature probe. When the problem is not the temperature probe it is a faulty timer board.
Posted on May 21, 2009
Can you get spare parts for a infra cheff
  • Infrachef Halogen Oven - Sears www.sears.com/search=infrachef halogen oven Replacement Parts. Schedule Repair. ... Home / Results For: "infrachef halogen oven" 67 results found for ... Infra Chef Halogen Oven.
  • Campkin's Parts Store - InfraChef Family Sized Halogen Oven www.campkins.com/Parts-Details.asp?sysid=2396 InfraChef Family Sized Halogen Oven . Web Price. $199.99. Category ... Quantity: Description: The revolutionary Infra Chef halogen oven is the all in one cooking ...
  • PROLECTRIX 7L HALOGEN OVEN SPARES REPAIR ' eBay www.ebay.co.uk > Search > PROLECTRIX 7L HALOGEN OVEN SPARES REPAIR Find best value and selection for your PROLECTRIX 7L HALOGEN OVEN SPARES REPAIR search on eBay. World's leading marketplace.
  • Amazon.co.uk: halogen oven spares www.amazon.co.uk > Search > halogen oven spares Amazon.co.uk: halogen oven spares. Amazon.co.uk Try Prime All ... Mini Halogen Thermostat made for SPARES2GO to fit Cookshop Mini Oven ...
  • Chef Oven Spare Parts ' Appliance Spares www.appliancespares.com.au/chef Appliance Spares in Nobel Park offers oven spare parts by Chef across the Australia to the top most manufacturers. Buy Now chef spares parts!
  • Jun 02, 2016 | Toaster Ovens
    Where can i find replacement control knobs for the front of the oven
    Farberware FAC900R Toaster Oven with Repair Questions ...
    www.fixya.com/support/...farberware_fac900r_toaster_oven_with/page-9
    Recent Farberware FAC900R Toaster Oven with Convection Cooking ... How do i find a replacement for the timer control knob for the toaster oven K4245H?
    Oct 15, 2015 | Farberware FAC900R Toaster Oven with...
    Euro-Pro Bravetti Model To283B
    You may have to start all over again with a replacement oven. Never, never, never use oven cleaner in this type of appliance!
    Oct 13, 2013 | Euro-Pro Toaster Ovens
    Display will not come on oster TSSTTVDFL1 toaster oven dead how to reset it?
    I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
    Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
    Jan 01, 2013 | Oster Toaster Ovens
    The blue light does not go on and the heating element does not wo
    The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
    Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
    My black and decker toaster oven is less than a year old and it has a burned out smell coming from it. I feel it might be a fire hazard and I am not comfortable using it anymore for fear of fire. What can...
    Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
    Mar 06, 2010 | Black & Decker CTO649 Toaster Oven with...
    The toaster oven does not toast. the oven and timer work, though
    Your selector switch may be broken if the oven works on selections other than toast.
    Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
    How to remove grease splatter from toaster oven
    set a bowl of ammonia in it over nite. do not turn oven on the fumes will ease the grease off. wipe clean in the morning with a dry cloth
    Sep 18, 2009 | Oster 6058 Toaster Oven with Convection...
    Where to buy handle for Sanyo SK-VF7S Oven
    http://cgi.ebay.com/Toaster-Oven-Sanyo-Convection-Oven-Digital-MSRP-$129.99... Discard Newest Oldest Positive Negative Recommended Be the first to Comment! Comment Posted, thanks! 0/500 characters Close Be the first to Comment! Comment Posted, thanks! 0/500 characters 0 http://cgi.ebay.com/Toaster-Oven-Sanyo-Convection-Oven-Digital-MSRP-$129.99_W0QQitemZ270334684635QQcmdZViewItemQQimsxZ20090125?IMSfp=TL090125074009r30521 0
    Jan 29, 2009 | Sanyo SK-VF7S 1350 Watts Toaster Oven with...
    Black & decker toster oven
    Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
    same problem here, toaster works, then when I go turn on the oven ........nothing!
    Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
    DeLonghi AR1070 Retro 1500 Watts Toaster Oven with Convection Cooking Logo
    172 people viewed this question
    Top DeLonghi Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Steve
    Craig Butler
    Craig Butler
    Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
