Question about KitchenAid KSRS25IL Side by Side Refrigerator
Outside middle devider hot
I noticed today that the freezer /refrigerator middle devider is hot to the touch it runs the full length of the appliance is this normal?
  • 473 Answers
Re: outside middle devider hot
It should be warm but not hot. If it is too hot then either the condensor coils underneath are too dirty or the condensor fan motor has failed.
Posted on Nov 12, 2007
0 characters
3 Points
Outside of freezer is hot to touch
If the unit was off for a while then more heat is inside the freezer after having it off for a while. That heat gets moved out to your condenser coil. Most freezers today don't have fans to force that heat to the outside air, they run that heat through the outer cabinet and it naturally travels to the cooler surrounding air. If there is no rear cover and no fan motor near that compressor this is how yours is designed. Just give it sometime and it should be fine. However it should be warm to the touch but not so hot you can't. And also depending on how long the freezer is running and how warm it is where the freezer is will affect how hot the outside is. The reason the outside of the freezer is hot is because that's how the freezer releases its heat from the refrigerant. The longer it runs or the harder it has to work the more heat it has to hive off. So unless the freezer is not cooling there is nothing to worry about.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 01, 2011 | KitchenAid Superba KSRG25FK Side by Side...
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
Refrigerator is very hot on the strip between the refrigerator and the freezer-no where else and it didn't use to be- I've checked it various times and it is very hot to the touch-the whoe length of the...
If you are referring to the outside part of the unit, you may have it too close to the wall behind it or you are lacking circulation. If your unit is still working fine, see if you can move it otherwise you may encounter problems in the future. IF you are having issues, the heating may just be a product. Have the unit cleaned inside, including the drain. Have all ice on the panel found at the far end inside the unit.
Jun 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works, refrigerator does not cool
Often the cooling section is located in the freezer and their is a hidden fan that blows the cold air into the lower section. If the fan quits working the refrigiator section wil not be cool.
Jun 19, 2009 | Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
GE GSS20IEPAWW Freezer Not cold outside of freezer very HOT
check to make sure that the fan in the back is working and then clean the condenser coil underneith the frig
Apr 26, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
KitchenAid KSRS25IL Side by Side Refrigerator Logo
195 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
