Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc2700 deep sleep - Brother MFC-8440 All-In-One Laser Printer
Tip
How Can a Sleep Mask Help Me?
Sleep isn't something that we can do without. Not everyone seems to need the same amout of hours sleep but a block of sleep is necessary every night in order to function well during the day.
Insomnia is a problem on some level for millions of people world wide and people use all sorts of solutions; from drugs to herbal remedies, meditation to sleep masks.
In order to feel rested, we need to have Deep Sleep. Sleep occurs in cycles. Deep sleep or REM is the fifth of the sleep cycles and is the most important one.
Deep sleep allows our minds to really sift through memories, stress and feelings. The body at this time might appear very active as extremitites can be twitchy and blood pressure and heart rate can increase but actually the body is going through a period of great rest.
So if deep sleep is so good for us - how do we get more of it?
Both quantity and quality matter when it comes to sleep. You need to sleep enough hours so that you have time for deep sleep cycles.
But when it comes to quality of sleep, there are things you can do to help yourself.
- Make sure you dont' have any lights left on. Even small computer lights can disturb sleep.
- Have a regular bedtime routine that you try and follow every day so that your body knows the signals.
- Use sleep masks to aid a deeper sleep. They will block out any tiny light and allow you to really fall into a deep sleep.
- Sleep masks are also really helpful for people who need to sleep with some light on.
Getting a good nights' sleep can help with mood, weight, memory and even our immunity to getting sick.
It's such a simple need and yet so many people don't listen to their bodies.
So I suggest that you invest in a sleep mask, follow the steps above and see if it helps you to feel better.
on Jan 06, 2014 | Health & Beauty
Deep sleep on printer
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000032479
Description of Problem 100000025364
How do I perform a firmware update or firmware upgrade on my Brother machine?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC7360N AllInOne Laser Printer
Going into deep sleep
Do you want to prevent your laptop from getting into deep sleep or are you having problem getting into deep sleep?
Sep 17, 2013 | Microsoft Computers & Internet
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
How do i get my vizio out of deep sleep?
That's funny :-)
How do you define "deep sleep" ?
What happens when you press the power button?
We specialize in Vizio 50HDTV10A and other similar 50'' plasma repairs and I am not ashamed to admit this is the first time I hear "deep sleep" associated with those TVs :-)
bobby @ coppelltvrepair
Apr 15, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Ipod in sleep mode
How to Enable Sleep Mode :
1. Access the main menu on your iPod
2. Go to the extras menu > clock
3. Select your current time ensuring that your timezone settings are correct
4. Select the Sleep Timer options
5. Select the time that you want your iPod to shut down
And if your iPod goes into Deep Sleep Mode then here is the answer to that :
Right "Deep Sleep" is a battery saving mode if the iPod is not touched in say a 18-24 hour period I think. It reboots (resets) coming out of this mode.
1) There are people reporting that they must always reset their iPod to turn it back on after shutting it off, they don't really mention deep sleep at all, search for "must always reset" or something along those lines
2) I'm not sure if this is documented anywhere specifically. It is a normal function of the iPod that we discovered somewhere along the line. Not sure where the first talk about it came from, you may find information on this searching "deep sleep" there was a hack to force the iPod immediately into deep sleep once upon a time.
3) Not exactly. If an iPod has gone into deep sleep, plugging it into the power will automatically start the reboot. In the case of buttons you should be able to touch a button and it will start to reboot, I have found with my 3G iPod it takes a very deliberate touch or two or three touches to the touch sensitive buttons to get it to wake up, but you shouldn't HAVE to do the reset command (i.e. menu/select button held down), if you do you may be looking at more of the original problemin #1
Sep 19, 2009 | Apple iPod touch
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
My sims ds lite
IT GOES 2 BED AT 9:00 I THINK
Jul 23, 2008 | Nintendo DS Lite Console
Brother MFC-8440 All-In-One Laser Printer Logo
316 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
