1995 Chevrolet Camaro Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am repairing my 1995 camaro with a 3.4 litre, i am replacing the intake gasket and the air intake plentum gasket, and valve cover gaskets, I am ready to reassemble and need to know were some bolts go, can you give me a site that will give me detailed pictures of what bolt goes were
Ned C Cook
Level 3:
President:
  • Chevrolet Master 3,433 Answers
  • Posted on Jul 08, 2009
Ned C Cook
Chevrolet Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1437318
Points
9966
Ok, common error. First group your bolts by their lokeness. length,diameter, and thread.. Then if you have 4 holes, find 4 bolts that fit. they should all protrude the same amount,about 1/2 in. Finger start only,about3-5 turns, use no tools. regardless of length if its in the right hole it will protrude the same as the others. Driy run if neededbut use no force on any of them. Good luck. Contact me if you have a question. If you force a long bolt down, you can punch a hole through something and a bolt too short won't take the torque or strip. phone 909 630 3192
Replace valve cover gasket
Remove wiper arms/ Remove wiper assembly/ Alternator/ Power Block/Remove intake manifold/ get new gaskets for that/ valve covers are now easily accesible . Great time to change the spark plugs and wires now. PCV valve/ Air Filter/The gaskets for my 3.3 '99 caravan were the thick rubber, and cost $120, For Valve cover gaskets, Get "THE RIGHT STUFF" and you can make your own set, black silicon gasket maker. Reassemble
tip
How to remove/replace the Valve Cover Gaskets on a New Beetle car?
Replace the valve cover gasket if the valve cover gaskets are leaking or if they're worn. The procedure is as follows:--
1) First of all let the motor cool down if the car was recently driven. Then remove the air intake boot.The air intake boot ios attached to the engine's throttle body.
2) Carefully disconnect the throttle cable , hoses and electrical connectors located on the upper intake manifold.
3) Then disconnect the hard pipe that is connected to the EGR (exhaust gas recirculation) valve.
4) The EGR valve is located beneath the upper intake manifold.
5) Then remove the bolts from both the upper intake manifold and the manifold support bracket.
6) Now the upper intake main fold and lower intake manifold both have got loose as you removed the nut.
7) After that remove the upper intake manifold from the lower intake manifold. Carefully place clean rags over the intake runners to prevent anything from falling into the intake system.
8) Then you will have to disconnect the crank case breather valve on the valve cover.
9) Then remove the bolts from the valve cover and remove the reinforcing straps.
10) Then remove the camshaft belt cover and the dust shield from the back of the camshaft sprocket.
11) Now carefully remove the valve cover. Properly clean the old gasket material with gasket remover.
12) You can install a new gasket in the reverse procedure of removal.
This will help. good luck.
Po300 on a 2001 mitsubishi galant
Here's a link on your code.You have spent a ton of money and the dealer would of done it cheaper.I take my vehicles to dealers for oil changes,they scan and will tell me for free what is wrong since I went there for a oil and not a repair job.Then I can fix my self and not be charged for there labor.
2answers
Oil leaks down back of motor on between tran and motor
the intake is leaking at back of engine replace intake gaskets
Changing pvc valve
1995 Geo Truck Tracker 4WD 1.6L TBI SOHC 4cyl
The PCV Valve is located under hood, center, upper engine area, top of engine, mounted in passenger side of intake manifold.
The low gas mileage and the versatility that your 1995 through 1999 Geo Tracker offers are two benefits of owning it. The maintenance needs to be kept up on your Geo Tracker. One form of this maintenance is to replace the valve cover gasket once you have driven 100,000 miles or more.
  1. Allow your engine to cool. Disconnect the negative battery cable. Remove the air inlet hose and air intake case or air cleaner housing. Detach the PCV valve hose from the PCV valve. Separate and remove the spark plug wires and the accelerator cable from their clips.
  2. Loosen and remove the valve cover bolts. Lift the cover up and off. Using a flathead screwdriver, gently nudge the gasket out of the gasket seating area. Using automotive engine cleaner and a clean cloth rag, clean the gasket seating area.
  3. Place the new gasket in the gasket seating area. Put the cover back into place. Put the bolts in and then using a torque wrench tighten them. Do not over tighten the bolts or the gasket will not fit correctly. Reconnect the spark plug wires and the accelerator cable in the holding clips.
  4. Reconnect the rubber hose to the PCV valve. Install the air intake case, or air cleaner housing, and the air inlet hose. Reconnect the negative battery cable. Add oil to the car and start the engine. Allow the car to run 10 to 15 minutes. This will allow the oil to lubricate the engine while it moves to the top.
I hope helps with this (remember rated this help) Good luck.
1995 Dodge ram 1500 V-8 5.9 litre 4x4 short bed is feels like it is bumping when the truck shifts into cruising gear and RPMs drop truck smmoths out when you speed up bumping goes away if you shift...
Perform compression check between cylenders #1 and #3. These are right next to each other.
You might get away with a head gasket replacement, if the compression between these cylenders is the same, indicating a blown head gasket between cyl.#1 and #3 not valves which will give different readins between these cylenders.
Instrution for lower intake repair 3.4 camaro
remove all accessories from front of engine -alt and ps pump,then drain cooling system ,remove upper intake- remove valve covers then lower intake.Then take out push rods to remove gasket(keep push rods in order as exhaust rods ar longer-will bend valves if installed wrong-get a piece or card board and punch in 12 holes 6and 6opposite each other,then put push rods in it)please not their is an updated gasket set from FEL PRO that has all you need to repair the problem with updates torque specs for lower manifold in the box REMEMBER change motor oil befor starting-you can even pour a little oil onto lifters before putting lower back this is to get any coolant from upper block to run into pan before oil change,if not knocking will occur in the next week
How do I change an intake exaust manafold
intake and exaust manifold are completely different issues...do you mean that you need to replace gasket for intake system,,,as this is very common on GM vehicles...if you dont know much about cars...you should leave it to someone who does,as it involves pulling the upper intake plentum,valve covers,sometimes push rods and then finally the intake....hope to have helped...LEE
My 1995 chrysler cirrus has alot of oil in with the spark plugs, what could cause that?
valve cover is leaking hard to replace rear gasket but front one isnt to bad for the rear the plentum has to be removed
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
