Just select to respective contact and select option, select delete for deleting and select edit for editing the contact. Kindly revert back for any further clarification.
Flick to All, find and tap the contact you want to edit, then tap Edit .
If this is a linked contact (a contact with multiple accounts that show up as one contact card), tap the account you want to edit (for example, tap Edit Windows Live).
Samsung ElectronicsTouch the "Create new contact" button and select the location or account you want toadd the contact to. ... or Custom by touching the label field (by default, this will showMobile). Touch to add more phone number fields, or touch to delete a field. ... Openthe contact you want to edit, and then touch Edit at the top of the screen ...
5 Parts: Create a new contact on Samsung Galaxy S5 Edit Contacts on SamsungGalaxy S5 Delete Contacts on Samsung Galaxy S5 Questions and Answers Comments ... Using Contacts, you can save a person's name, address, cellphonenumber, home number ... On the Phone field, enter your contact's phone numbers.
www.androidforum.com > Android Forum > Android Phones
Jun 25, 2015 - 10 posts - 10 authors
I aparently entered jumbled letters for this and cant delete or edit it. ... activated, I can hold down pressed on the number and 'edit it before calling' , but I still can't figure out how to edit the name or just delete the contact.
Depends on politics of each website and the "board" software.. Some let you edit or delete without restrictons, some give you a limited time and a limited number ot editions and on some you simply can't edit/delete anything.
All I can say, check your "user" menu. If any doubt or problem, there should be some way to contact webstie administrator or moderator. Though some don't have any way because really they are not iterested in your opinions and activity.
Now, actually you haven't even told us what website so can't help you more without additonal information
As you said me you want to delete some contact from you are phone memory means you can do this if you follow this things.Go to menu select contacts then scroll over to delete option and select that option after selecting that you will get two option telling delete all, one by one.If you select all contact will be deleted if you select one by one means you can delete one by one.If you want to edit the number means you can select menu and then contacts there you will get search select it and type the name after getting the contact select option then scroll over to edit number there you can edit.Thanks for you are question happy to help.
Set your phone to sinchronize your contacts with your PC (if not already set), and sync them. Then, start Outook on your PC, go to the Contacts tab, select the contacts you want to see excluded from your phone's internal memory, and delete them (either go to 'Edit > Delete', or 'Ctrl-D', or simply 'Del'). Now, re-synchronize your phone with your PC. I suppose ActiveSync on your phone will automatically delete the contacts you have excluded from Outlook on your PC.
Hope it works for you.
Cheers!
Carlos
To delete Google contact usernames simply go to the text field that displays them (under Edit Profile) and blank them out. Google will delete these IDs from their system.
For Editing Data: Retrieve the file to edited; touch [Shift], then either [< delete] or [> insert] to move the blinking cursor to the character or number to be edited. Touch [Shift] [< delete] for deleting or [Shift]
[> insert] for inserting a character, digit, or symbol.
For Deleting Data:
1) Find the Data to be deleted.
2) Touch [Shift][CE/C] ([CE/C] only depending on model) key. *DELETE?* is displayed.
3) Touch [Go]. *DELETE!* is displayed for 3 seconds then the data is deleted.
Note: If [CE/C] has been touched in error, simply touch any other key except the [GO] key to avoid deletion.
