Question about Sony Handycam CCD-TRV68 Camcorder
Black screen, it won't show nothing. it say (p71) on it
Re: Black screen, it won't show nothing. it say (p71) on...
Go to this site and call Sony. DO IT BEFORE SEPTEMBER 2008. Only certain models are included. Check the list. Mine of course, they claim is not included although it has the same problem.
Posted on Jun 26, 2008
Call 1-800-828-4040.....there is a defective chip that needs to be replaced and Canon will fix it for free. They even sent me free shipping lables as well....
Posted on Mar 11, 2008
0 characters
3 Points
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
My canon gl2 is showing a black screen but it will show menus and playback just nothing when i go to record
I think I had that same problem. I had to send it in to have the ribbon cable replaced to the flip out screen. I am trying to find the company I sent it to. Mine needs a tune up again.
I don't think it was cheap but it was cheaper than replacing the camera.
Oct 12, 2009 | Canon GL2 Mini DV Digital Camcorder
When I turn my camera on and try to record, nothing shows up on the screen.
Make sure lens cover is open, if still camcorder does not show live view then it is bad ccd imager chip problem that will be replaced.
Let me know exact model of your Sony camcorder to provide you part number info of ccd imager chip.
Sep 24, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Black screen when recording and only audio
are you sure your lens cover is off the lens? if the cover was on the lens you would only see black and it would still record audio
Aug 06, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Blank screen
I have the same problem the screen is just black when I cut it on can someone please help.
Dec 22, 2007 | Aiptek A-HD 720P Flash Media Camcorder
NO picture - JVC GR D74
Error Code E04 when I load a tape .
Oct 04, 2007 | Video Cameras
Gr-dvx7 jvc lcd screen is just white?
If the view finder shows the same white display. You probably have display circuit problem in the camera. Faulty CCD chip usually shows Black screen so it probably board problem or a connector problem. If you see an image through view finder then you may have defective connection from board to LCD assy. Either way it need to be looked at by a trained technician. Good luck.
Mar 17, 2007 | JVC GR-DVX7 Mini DV Digital Camcorder
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
Sony Handycam CCD-TRV68 Camcorder Logo
83 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
