There are several USB ports on my PC, no matter which I connect the Hard Drive, my PC is frozen, making it unable to access the backup files previously copied to the HD by the same PC. Now that I can't use the Buffalo HD, anyone has a solution?
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Was this helpful?
Yes
No
Popular Solutions for Buffalo Technology 250 GB Hard
packard bell store & save 2500. power light flashes greeen then stays orange and can't find...
(More)
packard bell store & save 2500. power light flashes greeen then stays orange and can't find drive on my computer
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it...
(More)
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it on my computer system freezes. It wont do anything until I disconnect the hard drive or turn it off. When I turn it off my system immediately starts to work again. I downloaded a driver detective that says the driver is up to date. Any suggestions?
I have a Buffalo HD-HB250U2-WR drive and when I connect it to power and my desktop, the red and...
(More)
I have a Buffalo HD-HB250U2-WR drive and when I connect it to power and my desktop, the red and green LEDs turn on, but after 30 seconds or so the Green LED turns off and I am not able to see the drive (no error messages of any sort). Any help will be appreciate it. Jay
