Question about Acer Aspire 5100 Notebook
Can not get on internet
Wireless light is on lan says unplugged and when i enable it it autmatically goes back to being unpugged.
My laptop keeps telling me that i have an unplugged wire for the internet, I have never had a wire for my internet. I get a great connection, I just dont know how else to log on.
Posted on Aug 10, 2009
  • 85 Answers
Which are you using, wireless internet or wired?
If your using wireless then:
Goto Control Panels via start menu
Double Click on network Connections
Right Click the LAN and choose Properties
On the bottom you see the "Show icon notification ..." make sure that is unchecked.
Close out and your good. no more notification.
Posted on Nov 12, 2007
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
I got a asus g53jw-a1 and when i connect my internet cable to it.it goes very slow and when i connect it to another laptop that isnt asus its goes normal and fast. i have 2 computers and the internet goes...
Do you have your wireless connection enabled as well as your LAN connection (wired) connected and enabled at the same time? It may be as simple as turning the your wireless card off when your are connected with a wired connection. I would try that first and see if it that could be the issue. Shut the wireless card off and see if your results are different with just the ethernet cable connected.
Cheers!
J the Guru
Oct 16, 2017 | ASUS G53Jw-A1 PC Notebook
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
I have a notebook aspire 6930, i've had it just barely over a year, and a couple days ago my internet just wouldn't connect. When i push the touch button to turn the wireless LAN on it does not light up...
1) Make sure Wireless Lan is Enabled by pressing the light button of it
2) Click with right button on the Battery Icon (on the botton bar aside clock)
3) Select Windows Mobility Center (a window will open up)
4) Click on "Turn wireless on" button.
Jun 12, 2010 | Acer Aspire 6930-6455 Notebook PC
I have a wireless-n 150 router. I have tried to use it with a Toshiba Windows Vista computer and I cannot get the wireless to work. I have unplugged it and plugged it back in and that doesn't do it. The...
The wireless router needs to configured with the wireless settings, SSID, encryption etc. Then the wireless card in the Toshiba needs to be configured with the wireless router's SSID, encryption etc.
To secure your wireless router from unauthorized access and to configure the wireless card in your computer so it can connect to your wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 11, 2010 | Office Equipment & Supplies
All works fine but computer will not go online, either by usb modem or broadband connection
Go to control panel, then go to internet properties. Make sure your device is enabled. Including wireless and LAN connections.
Keep in mind that you will have to unplug your router for 10 seconds and plug back in to remove static discharge. This is commom
Sep 16, 2009 | Advent Netbook
Does not operate
Be sure you can browse internet using wired LAN
Connect to Router using LAN cable and configure it.
Enable Radio and set security protocol.compatible with your PC wlan card.
Jan 09, 2009 | Linksys Wireless-G WET54G 802.11g/b...
Wireless internet
There will be a lapse in network communications as your laptop switches from LAN to Wireless, presumming that you have a Wireless access point in the area with DHCP enabled. If it doesn't work at all when unplugged from the ethernet, you may want to verify that your Wireless is turned on, and connecting to your network using the Wireless Network Configurator included with windows xp and above
-Backu
Jan 14, 2008 | Acer Aspire 5100 Notebook
Modem issues
If you are using wireless, make sure that the password is correct...
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
If not wireless.Unplug your router and modem for a few minutes.Then restart your computer, and plug the router and modem back in...
Jan 11, 2008 | Intel Motherboard
Acer Aspire 5100 Notebook Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
